• TOPICS
    • Design
    • Manufacturing
    • Inspection
    • Heat Treating
    • Lubrication
    • Materials
    • The Gear Industry
    • Gears by Type
  • MAGAZINE
    • Current Issue
    • Departments
    • Archives
    • Subscribe
    • Advertise
  • NEWSLETTER
    • Subscribe
  • VIDEO
    • Gear Technology TV
      • Ask the Expert Live
      • Revolutions
    • Industry Videos
  • BLOGS
  • BUYER'S GUIDE
  • NEWS and EVENTS
    • Product News
    • Industry News
    • Events
  • ADVERTISING
    • Brand Awareness
      • Print: Display Advertising
      • Online: Web Banners & Keyword Banners
      • Online: Native Advertising (Sponsored Content)
      • E-mail: Custom, White Papers & Webinars
      • E-mail: Newsletter Sponsored Content (Native Advertising)
    • Response & Lead Generation
      • Online: Sponsored Content (Native Advertising)
      • E-mail: Newsletters
      • Online: Buyers Guide
    • Print Advertising
      • Print: MPT Expo Showstoppers
      • Print: Buyers Guide
      • Print: Manufacturing sMart
      • Print: Specifications
      • MPT Expo Show Guide Advertising
    • Online Advertising
      • Online: Specifications
    • E-mail Advertising
      • E-mail: E-Newsletters
      • E-mail: AGMA Industry News
      • E-mail: Specifications
    • Special Promotions
  • CONTACT US
  • AGMA
    • Membership
    • Events
    • Education
    • Emerging Technology
    • AGMA Media
    • Standards
Subscribe
  • Sign In
  • Create Account
  • Sign Out
  • My Account
Home » Topics » Design » Contact Pattern
Contact Pattern
Contact Pattern RSS Feed RSS
Effects of Axle Deflection and Tooth Flank Modification on Hypoid Gear Stress Distribution and Contact Fatigue Life
August 1, 2009
As is well known in involute gearing, “perfect” involute gears never work perfectly in the real world. Flank modifications are often made to overcome the influences of errors coming from manufacturing and assembly processes as well as deflections of the system. The same discipline applies to hypoid gears.
Read More
Local 3-D Flank Form Optimizations for Bevel Gears
September 1, 2003
Dr.-Ing. Hartmuth Müller
Read More
Performance Analysis of Hypoid Gears by Tooth Flank Form Measurement
July 1, 2002
The traditional way of controlling the quality of hypoid gears' tooth flank form is to check the tooth flank contact patterns. But it is not easy to exactly judge the tooth flank form quality by the contact pattern. In recent years, it has become possible to accurately measure the tooth flank form of hypoid gears by the point-to-point measuring method and the scanning measuring method. But the uses of measured data of the tooth flank form for hypoid gears have not yet been well developed in comparison with cylindrical involute gears. In this paper, the tooth flank form measurement of generated face-milled gears, face-hobbed gears and formulate/generated gears are reported. The authors discuss the advantages and disadvantages of scanning and point-to-point measuring of 3-D tooth flank forms of hypoid gears and introduce some examples of uses of measured data for high-quality production and performance prediction.
Read More
The Next Step in Bevel Gear Metrology
January 1, 1996
Dr. Hermann J. Stadtfeld
Read More
Tooth Root Stresses of Spiral Bevel Gears
May 1, 1988
Read More
Bevel Gear Development and Testing Procedure
July 1, 1986
Read More
Viewpoint
May 1, 1986
Sub: 'Finding Tooth Ratios' article published in Nov/Dec 1985 issue Let us congratulate you and Orthwein, W.C. for publishing this superb article in Gear Technology Journal. We liked the article very much and wish to impliment it in our regular practice.
Read More
Influence of Relative Displacements Between Pinion and Gear on Tooth Root Stresses of Spiral Bevel Gears
July 1, 1985
The manufacturing quality of spiral bevel gears has achieved a very high standard. Nevertheless, the understanding of the real stress conditions and the influences. of certain parameters is not satisfactory.
Read More
Analyzing Gear Tooth Stress as a Function of Tooth Contact Pattern Shape and Position
January 1, 1985
The development of a new gear strength computer program based upon the finite element method, provides a better way to calculate stresses in bevel and hypoid gear teeth. The program incorporates tooth surface geometry and axle deflection data to establish a direct relationship between fillet bending stress, subsurface shear stress, and applied gear torque. Using existing software links to other gear analysis programs allows the gear engineer to evaluate the strength performance of existing and new gear designs as a function of tooth contact pattern shape, position and axle deflection characteristics. This approach provides a better understanding of how gears react under load to subtle changes in the appearance of the no load tooth contact pattern.
Read More
A Second Rate Society - Never
August 1, 1984
What was once recognized as the unique genius of America is now slipping away from us and, in many areas, is now seen as a "second rate" capability. Unless action is taken now, this country is in real danger of being unable to regain its supremacy in technological development and economic vigor. First Americans must understand the serious implications of the problem; and second, we must dedicate ourselves to national and local actions that will ensure a greater scientific and technological literacy in America.
Read More
Previous 1 2 Next
Free Gear Technology Subscriptions
Subscribe
Subscribe
FEATURED VIDEO
  • Helios1
    Forest City Gear Taps Helios Gear for Custom Cutting Tools
January 18, 2023
RECOMMENDED
  • Precision Equals Performance at ZPE GripTec
    October 12, 2022
  • State of the Powder Metal Industry
    October 12, 2022
  • The Afterglow of Furnaces North America 2022
    October 12, 2022
  • Reigniting the Educational Infrastructure
    December 5, 2022
  • Profile: Continuing Education and Training with the AGMA
    December 5, 2022
    December 5, 2022
    December 5, 2022
    October 12, 2022
  • Subscribe
  • Advertise
  • Contribute
  • AGMA
Powered byAGMA
Copyright © 2023 Gear Technology
  • Privacy Policy
  • Contact
