The new KISSsoft release 2024 is coming soon! This April will bring you the new system module KISSdesign, accelerating the calculation of complex drive trains and replacing the previous KISSsys software.
A good 20 years have passed since the web-based calculation software eAssistant saw the light of day in the digital world. The software is probably the oldest commercial online solution for the design, recalculation and optimization of machine elements such as shafts, bearings, shaft-hub connections, gears, bolted joints, springs, etc. The calculations are based on internationally accepted standards and guidelines as well as technical literature.
The loaded tooth contact analysis (LTCA) is crucial in understanding the deformation of gears and its impact on various factors such as noise generation, contact patterns, contact shocks, and torque variations. With the contact analysis feature in KISSsoft, users can calculate tooth contact under specific torque and speed levels, thereby assessing the performance of gears and gearboxes.
GWJ Technology GmbH, a calculation specialist from Braunschweig, Germany, added new functions to the gear modules of its eAssistant web-based calculation software, which has been successful for more than 20 years.
In an urgent assignment, a gear has to be designed, with the engineer already knowing the required reduction ratio, torque and speed. On the manufacturing side, the preferred materials, possible qualities and the reference profiles are specified. This initial situation represents an everyday task.
The new KISSsoft release 2023 comes with numerous novelties. Among others, Gear Mesh Frequencies (GMF) can now be calculated for cylindrical and bevel gears. GMF results are visualized in two different diagrams, i.e. GMF versus rotational frequency of the reference gear, and GMF versus amplitude.
GWJ Technology GmbH has extended the output option of tooth forms of involute gears. GWJ has extended the output of tooth forms in 2D DXF format in its calculation modules single cylindrical gears, cylindrical gear pairs, planetary gear trains, three- and four-gear train systems, gear racks and involute splines as part of the new versions of its calculation solutions eAssistant and TBK.
A new version of the MESYS shaft and rolling bearing analysis software including new functionality is available. The bearing analysis software allows the calculation of the load distribution within the bearing and bearing life according to ISO/TS 16281 and it is integrated in a shaft system calculation with additional possibilities like modal analysis, strength calculation for shafts and interfaces to gear calculations. Currently the software is used by customers in 30 countries on four continents.
2022 marks the 20th Anniversary of SMT’s focus on providing the tools and knowledge to drive engineering innovation in gearbox system analysis. With this historic company anniversary, the company has announced the return of the North America User Forum.
SEGULA Technologies and British scale up Senseye, specialized in predictive maintenance based on artificial intelligence, have announced the signing of a partnership.
