In modern automotive vehicles, gear noise becomes more and more of an issue. The main reason is the reduced masking noise of the engine, which vanishes completely in the case of an electric driveline. Improved gear quality unfortunately does not correlate with a better noise performance in any case. High gear quality makes sure that the gear flanks are inside tight tolerances and that all teeth are nearly identical. Even if the running behavior of such gear sets shows a very low sound pressure level, the noise perception for human ears may be annoying.
In this latest edition, issue 9, of the GEARS inline Customer Magazine, Klingelnberg once again presents all sorts of trends and innovations from the world of gears. This time, the machine manufacturer focuses primarily on the hot topic of noise behavior and analysis.
New GRSL technology adds value to high-volume transmission gear inspection by combining non-contact laser inspection with tried-and-true composite roll testing.
Plastic gears are everywhere
Part I of this paper describes the theory behind double-flank composite inspection, detailing the apparatus used, the various measurements that can be achieved using it, the calculations involved and their interpretation. Part II, which will appear in the next issue, includes a discussion of the practical application of double-flank composite inspection, especially for large-volume operations. Part II covers statistical techniques that can be used in conjunction with double-flank composite inspection, as well as an in-depth analysis of gage R&R for this technique.
This paper presents a new approach in roll testing technology of spiral bevel and hypoid gear sets on a CNC roll tester applying analytical tools, such as vibration noise and single-flank testing technology.
