Austempering heat treatments
(austenitizing followed by rapid cooling
to the tempering temperature) have been
applied to nodular irons on an experimental basis for a number of years, but commercial interest in the process has
only recently come to the surface.
This paper addresses Austempered Ductile Iron (ADI) as an emerging Itechnology and defines its challenge by describing the state-of-the-art of incumbent materials. The writing is more philosophical in nature than technical and is presented to
establish a perspective.
