As most of you know by now, the trade show formerly known as Gear Expo is now the Motion + Power Technology Expo. If you're a gear-industry veteran, you might be confused by this change. If you've been coming to the show for years - or exhibiting at it - you might even feel a little betrayed. But I'm here to tell you it's going to be alright.
Overall, the gear industry enjoyed a very strong 2018, and the optimism expressed by survey respondents is the highest in recent years. When asked about their optimism regarding their companies’ ability to compete over the next five years, 85.8% of respondents indicated some level of optimism.
This paper analyzes the different influences of the deviations between nominal and actual geometry for a first-cut bevel gear. In each section, the customary tolerances are quantified and the possibilities to reduce them are discussed.
