If you make hardened gears and have not seen any micropitting, then you haven’t looked closely enough. Micropitting is one of the modes of failure that has more recently become of concern to gear designers and manufacturers. Micropitting in itself is not necessarily a problem, but it can lead to noise and sometimes other more serious forms of failure. Predicting when this will occur is the challenge
facing designers.
The October 2011 issue of Gear Technology featured the article “Low-Distortion Heat Treatment of Transmission Components,” which covered
the combination of low-pressure
carburizing and high pressure gas quenching in an automotive environment. Here, heat treating expert Dan Herring explains why oil quenching is an appropriate choice for many applications.
When the term, “what you see is what you get” is applied in the computer
industry, it means that users or customers are able to see their end
results without the encumbrances of
complicated software code that enables
this function. Software works behind
the scenes ultimately to produce transparency and the desired effects. In
many ways, this concept should be
extended to the relationships that exist
between suppliers and buyers and even
among internal company departments.
