SCHUNK Introduces New Workholding Technique April 11, 2006 SCHUNK's new line of magnetic clamping technology can be optimally applied when used in conjunction with the company's quick-chan...Read More
SKFs New Cylindrical Roller Bearings Extend Wind Turbine Gearbox Life April 11, 2006 New SKF high-capacity cylindrical roller bearings for wind turbine gearboxes have been engineered to promote longer gearbox service life...Read More
Ondrives New Gearbox Emphasizes Torque and Speed April 11, 2006 A new line of DC motorized worm and wheel reduction gearboxes from Ondrives is fitted with 24V DC motors that operate at 12V DC. Accor...Read More
Alpha Gear New Gearhead Follows Trends in High Reduction Torque and Ratios April 11, 2006 The new SPK+ right-angle gearhead is designed for applications with high reduction ratios and torques. This product combines features of...Read More
Alpha Gears Gearmotor Offers Significant Reduction in Inertia April 11, 2006 The TPM from alpha gear drives Inc. is a geared motor containing a rotary actuator based on an AC servo motor and high precision planetar...Read More
DSMs Stanyl Precison Gears Help Disabled Patients Drive Independently April 11, 2006 Precision gears made out of Stanyl, a high-performance polyamide 46 (PA46) resin from DSM Engineering Plastics, help keeps the Joyster mo...Read More
Marposs New Gage Head Designed for Internal Grinders April 11, 2006 The Thruvar from Marposs is a through-the-spindle gage for in-process measurement application on internal grinding machines and was intro...Read More
United Grinding?s Newest Machine Grinds Shafts and Chucked Workpieces April 11, 2006 [photo] The Studen S242 from United Grinding is designed for the hard turning and grinding of high-precision applications for both shaf...Read More
Boston Gear Publishes Gearhead Brochure April 8, 2006 Boston Gear has published a full color, 36-page brochure to introduce a new high precision helical planetary gearheads The gearheads ...Read More
Parker Expands Its PowerStation Family April 8, 2006 Parker Automaton-CTC introduced the EPX10S, which is equipped with a 10" TFT, SVGA display and analog resistive touchscreen. It joins th...Read More
