Information is the name of the game in the 90s. We need more of it; we need it faster; and we need it in infinitely manipulatable and user-friendly form. In many cases, getting it that way is still something of a Holy Grail, somewhere off on the distant horizon. But thanks to computer technology, bit by byte, we're getting there.
Indianapolis is a nice city. No. It's a great city for a convention. The facilities and the city are modern, clean and bright. The Convention Center is easy to get to by either car or plane, and its central location in the heart of town and the enclosed skyway system between it and major hotels put visitors close to amenities like restaurants, shopping and entertainment. The people are friendly and go out of their way to make visitors feel welcome.
Gears are manufactured with thin rims for several reasons. Steel gears are manufactured with thin rims and webs where low weight is important. Nonmetallic gears, manufactured by injection molding, are designed with thin rims as part of the general design rule to maintain uniform thickness to ensure even post-mold cooling. When a thin-rimmed gear fails, the fracture is thought the root of the gear, as shown in Fig. 1a, rather than the usual fillet failure shown in Fig. 1b.
Your Addendum team has come across a number of Good Ole Boys in its time; now we bring you something of even more interest - a Good Ole Gear Book. Mr. Robert Price, of Automation - Gears - Machinery, a gear consulting firm in Delanson, NY, shared with us a real find.
