• TOPICS
    • Design
    • Manufacturing
    • Inspection
    • Heat Treating
    • Lubrication
    • Materials
    • The Gear Industry
    • Gears by Type
  • MAGAZINE
    • Current Issue
    • Departments
    • Archives
    • Subscribe
    • Advertise
  • NEWSLETTER
    • Subscribe
  • VIDEO
    • Gear Technology TV
      • Ask the Expert Live
      • Revolutions
    • Industry Videos
  • BLOGS
  • BUYER'S GUIDE
  • NEWS and EVENTS
    • Product News
    • Industry News
    • Events
  • ADVERTISING
    • Brand Awareness
      • Print: Display Advertising
      • Online: Web Banners & Keyword Banners
      • Online: Native Advertising (Sponsored Content)
      • E-mail: Custom, White Papers & Webinars
      • E-mail: Newsletter Sponsored Content (Native Advertising)
    • Response & Lead Generation
      • Online: Sponsored Content (Native Advertising)
      • E-mail: Newsletters
      • Online: Buyers Guide
    • Print Advertising
      • Print: MPT Expo Showstoppers
      • Print: Buyers Guide
      • Print: Manufacturing sMart
      • Print: Specifications
      • MPT Expo Show Guide Advertising
    • Online Advertising
      • Online: Specifications
    • E-mail Advertising
      • E-mail: E-Newsletters
      • E-mail: AGMA Industry News
      • E-mail: Specifications
    • Special Promotions
  • CONTACT US
  • AGMA
    • Membership
    • Events
    • Education
    • Emerging Technology
    • AGMA Media
    • Standards
Subscribe
  • Sign In
  • Create Account
  • Sign Out
  • My Account
Home » Topics » Design
Design
Design RSS Feed RSS
Stress of Planet Gears with Thin Rims
March 1, 1994
This article discusses the relationships among the fillet stress on a thin rim planet gear, the radial clearance between the gear rim and the gear shaft, the tooth load, the rim thickness, the radius of curvature of the center line of the rim, the face width and the module.
Read More
The Fundamentals of Gear Press Quenching
March 1, 1994
Most steel gear applications require appreciable loads to be applied that will result in high bending and compressive stresses. For the material (steel) to meet these performance criteria, the gear must be heat treated. Associated with this thermal processing is distortion. To control the distortion and achieve repeatable dimensional tolerances, the gear will be constrained during the quenching cycle of the heat treatment process. This type of fixture quenching is the function of gear quench pressing equipment.
Read More
Generation of Helical Gears with New Surface Topology by Application of CNC Machines
January 1, 1994
Read More
The Gear Hobbing Process
January 1, 1994
Read More
Calendar
January 1, 1994
Complete calendar for January/February 1994
Read More
CBN Gear Grinding - A Way to Higher Load Capacity
November 1, 1993
Read More
Hob Basics Part II
November 1, 1993
Read More
Maximum Life Spiral Bevel Reduction Design
September 1, 1993
Read More
Hob Basics Part I
September 1, 1993
The Hobbing Process The hobbing process involves a hob which is threaded with a lead and is rotated in conjunction with the gear blank at a ratio dependent upon the number of teeth to be cut. A single thread hob cutting a 40-tooth gear will make 40 revolutions for each revolution of the gear. The cutting action in hobbing is continuous, and the teeth are formed in one passage of the hob through the blank. See Fig. 1 for a drawing of a typical hob with some common nomenclature.
Read More
Contact Analysis of Gears Using a Combined Finite Element and Surface Integral Method
July 1, 1993
The complete and accurate solution t the contact problem of three-dimensional gears has been, for the past several decades, one of the more sought after, albeit elusive goals in the engineering community. Even the arrival on the scene in the mid-seventies of finite element techniques failed to produce the solution to any but the most simple gear contact problems.
Read More
Previous 1 2 … 121 122 123 124 125 126 127 128 129 … 139 140 Next
Free Gear Technology Subscriptions
Subscribe
Subscribe
FEATURED VIDEO
  • Helios1
    Forest City Gear Taps Helios Gear for Custom Cutting Tools
January 18, 2023
RECOMMENDED
  • Precision Equals Performance at ZPE GripTec
    October 12, 2022
  • State of the Powder Metal Industry
    October 12, 2022
  • The Afterglow of Furnaces North America 2022
    October 12, 2022
  • Reigniting the Educational Infrastructure
    December 5, 2022
  • Profile: Continuing Education and Training with the AGMA
    December 5, 2022
    December 5, 2022
    December 5, 2022
    October 12, 2022
  • Subscribe
  • Advertise
  • Contribute
  • AGMA
Powered byAGMA
Copyright © 2023 Gear Technology
  • Privacy Policy
  • Contact
