This article discusses an application driven approach to the computer-aided sizing of spur gear teeth. The methodology is bases on the index of tooth loading and environment of application of the gear. It employs handbook knowledge and empirical information to facilitate the design process for a novice. Results show that the approach is in agreement with the textbook data. However, this technique requires less expert knowledge to arrive at the conclusion. The methodology has been successfully implemented as a gear tooth sizing module of a parallel axis gear drive expert system.
shafts.
One of the current research
1984 by the author
techniques.
History comes around full circle. It is interesting to talk to gear manufacturers who service the defense, aerospace, automotive and computer industries and find that their sales, production and backlogs reflect excellent and, in some cases, record breaking business.
