Another young man discovers you need not be an expert machinist to succeed as a gear engineer. Spoiler alert: never tangle with a grinding wheel; they are undefeated in all time.
Cubic Boron Nitride (cBN) abrasive wheels, which are a specially engineered abrasive grain referred to as a superabrasive, typically yield 2,200 - 2,500 parts per dress with one wheel lasting as long
as four to six months.
With increasingly smaller returns from improving the speed of the actual gear grinding process, improving your setup time has become a primary way to keep improving efficiency. Here's the latest on how you can do that today.
The grinding/abrasives market is rapidly changing, thanks to new technology, more flexibility and an attempt to lower customer costs. Productivity is at an all-time high in this market, and it’s only going to improve with further R&D. By the time IMTS 2014 rolls around this September, the gear market will have lots of new toys and gadgets to offer potential customers. If you haven’t upgraded any grinding/abrasives equipment in the last five years, now might be a good time to consider the investment.
