This is the final part of a three-part series on the basics of gear lubrication. It covers selection of lubricant types and viscosities, the application of lubricants, and a case history
These lines, interesting enough, are from the notebooks of an artist whose images are part of the basic iconography of Western culture. Even people who have never set foot in a museum and wouldn't know a painting by Corregio from a sculpture by Calder, recognize the Mona Lisa. But Leonardo da Vinci was much more than an artist. He was also a man of science who worked in anatomy, botany, cartography, geology, mathematics, aeronautics, optics, mechanics, astronomy, hydraulics, sonics, civil engineering, weaponry and city planning. There was little in nature that did not interest Leonardo enough to at least make a sketch of it. Much of it became a matter of lifelong study. The breadth of his interests, knowledge, foresight, innovation and imagination is difficult to grasp.
The effect of various lubricant factors on wormgear efficiency has been evaluated using a variety of gear types and conditions. In particular, the significant efficiency improvements
afforded by certain types of synthetic
lubricants have been investigated to determine the cause of these improvements. This paper describes broad wormgear testing, both in the
laboratory and in service, and describes the extent to which efficiency can be affected by
changes in the lubricant; the effects of viscosity, viscosity index improvers and, finally, synthetic lubricants are discussed. The work concludes that lubricant tractional properties
can play a significant role in determining gear efficiency characteristics.
