Revolutions
November 18, 2026
Aaron Fagan
Shot Peening Micropitting Revolutions
A Shot Peening Primer
This primer covers the basics of shot peening and recent research on its use for gears. The research falls into three areas: the effect of peening on gear flank durability, methods for measuring the process and the part during production, and models that account for wear of the peening media. Most of the work applies to carburized gears.
The Basics
Shot peening is a cold working process. Small spherical media, usually cast steel shot, conditioned cut wire, glass beads or ceramic beads, are thrown at a part's surface, and each one leaves a small dimple, stretching the surface metal while the material below resists the deformation. Overlapping dimples leave a thin, even layer of residual compressive stress, typically at least half the yield strength of the material (shotpeener.com). Fatigue cracks start at the surface and grow under tension, so a layer held in compression resists both their start and their growth.
The process is specified by two values, intensity and coverage. Intensity is the energy of the shot stream, measured on an Almen strip, a standard strip of spring steel that bows when one side is peened. John O. Almen developed the test at General Motors while peening engine valve springs, and his patent was granted in 1944 (The Shot Peener, Summer 2026). Strips come in three thicknesses: N (about 0.031 in.), A (about 0.051 in.) and C, the thickest, for heavy peening. Strips are peened for increasing times and the arc heights are plotted, and the intensity is the arc height at saturation, the point past which doubling the peening time raises the arc height by no more than 10 percent (Kirk, The Shot Peener, Spring 2012). A specification of 12A means an arc height of 0.012 in. on an A strip.
Coverage is the share of the surface dented at least once, judged by eye. It cannot be measured past 100 percent, so higher figures are stated in time: 200 percent coverage, as in the CETIM tests below, means peening twice as long as it took to reach 100 percent (Wikipedia).
On gears, peening is used most at the tooth root, where it raises bending fatigue strength, and the standards give it credit there. Its effect on the tooth flank, where gears fail by pitting and micropitting, is the subject of most of the current gear research.
Effect on Gear Flank Durability
A recent gear study comes from CETIM, France's technical center for the mechanical industries. Dalia Jbily, Luc Amar and André Simonneau ran ground, case-hardened 18CrNiMo7-6 spur gears (module 4.5 mm, 16 and 24 teeth) with and without shot peening in a back-to-back rig at FZG load stage 10, and reported the results in the November/December 2024 issue of Gear Technology.
Peening did not delay micropitting. It appeared in the dedendum of both sets after the same running time, and it spread over a larger area on the peened flanks. The two sets differed at the macropitting stage. The ground gears spalled after about 8.85 million cycles (66 hours), while the peened pinion lasted to about 28 million cycles (209 hours) before its first macropitting, and a peened set run to 239 hours had no widespread spalling.
Peening put compressive stress into a layer about 40 µm deep and lowered roughness, but the specific film thickness λ stayed below 1 on both sets, so the surface asperities remained in contact and micropitting occurred on both sets. The authors credit the longer pitting life to the compressive layer, which slows the growth of the cracks that lead to pits and spalls.
The FZG Gear Research Center at TU Munich reported similar findings for a different gear and steel. Dominik Kratzer, Johannes König, Thomas Tobie and Karsten Stahl tested eight peening and superfinishing variants on 16MnCr5 gears and reported that peening raised flank load capacity, superfinishing significantly reduced micropitting, and the higher compressive stress from peening had no significant effect on micropitting (Gear Technology, March/April 2021). The pitting benefit was documented earlier: NASA tests in 1982 found peened AISI 9310 gears reached 1.6 times the pitting life of unpeened ones.
Process Measurement
Almen intensity and coverage tell an operator what the strip received, not what the part received, and coverage above 100 percent can only be estimated by extrapolating a model fit. X-ray diffraction and hole drilling measure residual stress directly, but they are slow and they destroy the sample. Two research groups are working on ways to measure the result during the process.
At Purdue University's School of Materials Engineering, R. Varma, L. Feltner, D. Johnson and P. Mort are developing optical profilometry for in-process certification. The method scans the peened surface, filters out the ordinary dimples to find defects, and maps the optical signature of the surface to the residual stress profile beneath it. The goal is to certify parts on the production line without destructive testing (Purdue Peener, May 2026).
A second approach measures shot velocity. Gioacchino Salvagio and Khaled Tlili of Sonaca Montreal, with Christopher Bousquet-Jetté of the Centre Technologique en Aérospatiale, measured particle velocity with a Tecnar Shotmeter G3 for three media types at 20 to 80 psi and compared it with Almen arc heights. Intensity tracked velocity in a straight line for all three, with R² values from 0.990 to 0.999, which means velocity could be used to estimate intensity during production and reduce the need for Almen checks before each run (The Shot Peener, Spring 2026). The authors note the correlation weakens as media wears or breaks, so media condition still has to be controlled.
Process Modeling
During production, shot wears and fractures and is periodically replenished, and these changes affect the residual stress in the parts. Langdon Feltner and Paul Mort at Purdue built a process model of an industrial peening line that follows the media as it degrades and uses a neural network, trained on finite-element simulations, to predict the resulting residual stress field. The network matched the finite-element results to within about 0.15 GPa on a mean stress of about 0.82 GPa (Materials, December 2025).
The model also showed that the way operators recharge the media changes the stress in the part. In one case study, adding a large charge of new shot to a large quantity of used shot shifted the residual stress about 25 MPa toward the less compressive side. Purdue's next step is closed-loop control, in which sensor data on velocity, load, acoustics and media flow feed the model and the process is adjusted automatically. Equipment makers are moving in the same direction with robotic, sensor-equipped machines, such as the sentenso PeenBot described in The Shot Peener in October 2026.
Surface Roughness Parameters
Ra averages the height of a surface and says little about its shape, which affects how asperities interact in a gear contact. The Shot Peener published "Profile Characterization of Surface Roughness in Shot Peening" in its October 2026 issue, on texture measures beyond Ra.
Two gear studies show the effect. CETIM measured six parameters on its test flanks and used skewness (Rsk) and kurtosis (Rku), which describe whether a surface is dominated by peaks or valleys and how sharp the peaks are, to judge micropitting risk. In a study of the ISO/TS 6336-22 micropitting method published in 2023, John Amendola, Robin Olson, Mark Michaud and Jon Keller found that switching the roughness input from Ra to Rz cut one gearset's safety factor from 1.93 to 1.21 (Gear Technology, June 2023). The calculated result depends on the roughness parameter used, and the right choice for a peened surface has not been settled.
Alternative Processes
Peening improves pitting resistance, and a smooth flank improves micropitting resistance. Several processes aim to provide both.
ApproachSourceFindings
Peen first, then grind and polishFZG, TU Munich, FVA 521/IV (finished 2023)Intensive peening right after heat treatment left a compressive layer deep enough to survive grinding and polishing; the gears showed "extremely high" pitting capacity with no added process steps over conventional grinding
Peening plus superfinishingKratzer, König, Tobie and Stahl, FZG (2021)Conventionally peened and superfinished gears ran 62 million cycles at 1,750 N/mm²; a more intense variant that left small surface cracks ran fewer cycles (48 million)
Laser shock peeningXue Cheng and colleagues, Journal of Aeronautical Materials (February 2025)On gear steel, a four-layer overlapping laser path gave a more even compressive stress field; gains from more energy and more impacts leveled off
Fine particle peeningZhang, Liu, He and Guagliano, Fatigue & Fracture of Engineering Materials & Structures (2024)A contact fatigue model for AISI 9310 aviation gear steel that accounts for topography, residual stress and hardness, used to set a process window for the peening parameters
The FZG process does not add a production step; it changes the order of existing steps. The laser shock peening and fine particle peening studies come from aerospace gear research.
Standards and Design Implications
ISO 6336 credits shot peening only at the tooth root, where it raises bending strength for carburized gears by 10 percent for MQ material and 5 percent for ME. Nothing in the pitting calculation reflects the compressive layer, so a peened flank is rated the same as a ground one. In the CETIM tests, ISO 6336-2 put generalized pitting on the pinion at 10.12 million cycles, close to what the ground gears did, and the peened gears ran well beyond that. The FZG group has proposed a surface factor, ZS, to bring peening into the flank rating, with the caution that it needs more test data before wider use.
For gear designers, the research so far supports these conclusions:
  • Peening extends pitting life but will not prevent micropitting when λ is below 1. Surface finish and the lubricant decide that.
  • A high ISO/TS 6336-22 safety factor is no guarantee against micropitting. CETIM saw micropitting with factors above 2, and Amendola and colleagues saw it on a compressor gearset with factors above 7.
  • Standard ratings understate the flank capacity of peened gears, so any credit for peening has to come from testing or field experience.
  • Process control is moving from the Almen strip toward measuring shot velocity, tracking media condition and checking the part itself, which should make the stress a gear receives more repeatable from batch to batch.
The CETIM authors plan friction tests next, to relate the friction coefficient to the peened surface and tune the peening parameters for a better finish.
