DN Solutions Unveils NHP 6300 Horizontal Machining Center
DN Solutions recently unveiled its second-generation NHP 6300 horizontal machining center, offering reduced cycle times, enhanced spindle performance, and seamless automation integration.
Engineered to slash non-cutting time, the second-generation NHP 6300 boosts spindle acceleration and deceleration rates by 20 percent over its predecessor. Table indexing is 35 percent faster, and table rotation speed has more than doubled, significantly reducing cycle times and driving higher throughput. Tool change times are 30 percent faster, further minimizing downtime between operations.
The second-generation NHP 6300 features a high-speed 12,000 r/min 50 taper built-in spindle, with a 15,000 r/min spindle available as an option. Vibration and thermal distortion are minimized to deliver exceptional stability and precision during heavy-duty cutting or extended operation. Integrated cooling for the spindle shaft and nut assemblies, paired with advanced thermal compensation, preserves machining accuracy throughout prolonged cycles.
A hallmark of the NHP series is its standard B-axis rotary table and automatic pallet changer (APC). These components enable complete five-sided machining in a single setup and support uninterrupted production by alternating between two pallets.
Automation-ready, the second-generation NHP 6300 seamlessly integrates with systems such as the Linear Pallet System (LPS) and enables 24/7 lights-out manufacturing via smart tool-wear prediction, advanced process scheduling, and defect-prevention logic.
To enhance operational efficiency, the second-generation NHP 6300 features an optional Sludge-Free Coolant (SFC) tank that automatically filters chips and sludge, reducing maintenance downtime and maximizing machine availability.
With its robust design, precision control, and automation flexibility, the second-generation NHP 6300 provides a comprehensive solution for manufacturers seeking faster, smarter, and more reliable horizontal machining.
