Hard Finishing of Cylindrical Gears: Power Skiving with Integrated Cutter Resharpening
For the past decade Gleason has been building Power Skiving machines at its Gleason-Pfauter facilities in Ludwigsburg, Germany. As the many benefits of this technology have become widely recognized, Gleason Power Skiving machines have been at the forefront, and the series has grown to include models for internal and external cutting and finishing of gears as large as 800 mm in workpiece diameter. Now, with the demands for gear quality reaching new levels and hard finishing becoming increasingly common, Gleason is again pushing the Power Skiving envelope to meet these requirements.
Hard Finishing Requires a New Approach
Manufacturing carburized and hardened gears with Power Skiving has always taken the traditional approach: after a cutter has reached its wear or quality limit, the operator changes the cutter, adjusts the cutter data, cuts the next workpiece, transfers it to the inspection room, waits for the first part inspection and, if necessary, corrects the process by adjusting the machine parameters before proceeding with serial production.
This traditional approach to cutter refurbishing, which usually takes anywhere from 45 to 60 minutes, is time consuming and laborious, but vital to ensure that the cutting tools produce high quality parts throughout their useful life. Of critical importance is the amount of edge roundness, which is difficult to produce and control, and has a great impact on the hard finishing process requiring precise removal of very thin chips.
The non-productive time needed for cutter refurbishment is particularly evident in Power Skiving, a very fast process that requires frequent cutter changes and first part cycles. The required procedure increases tool cost, inventory and, most significantly, non-productive time and resources needed for cutter management, handling and sending used cutters to refurbishing (resharpening and recoating) and returning cutters into production.
Revolutionary Concept: On-Board Cutter Sharpening for Hard Finishing
By adding the capability of resharpening carbide cutters directly on the Power Skiving machine, Gleason has taken a revolutionary step forward in raising the economy and quality for hard finishing carburized and hardened gears. This new development enhances the benefits of Power Skiving in virtually every significant area.
Today, a fully-integrated, on-board sharpening unit is available for the vertical series of Gleason Power Skiving Machines up to 600 mm in diameter. The cutter face can now be resharpened fully automatically in the machine after it has cut a certain number of gears, without any operator involvement. The cutter geometry is continuously adjusted automatically to compensate for stock removal, and serial production is continued without interruption. Recoating the cutting face is not required because the original coating on the flanks sufficiently protects the cutter teeth.
