Index to Showcase C200 Fanuc Production Turning Center at Westec 2025
Index will be demonstrating its C200 Fanuc at Westec 2025. Initially introduced in late 2024, this cost-effective new variant of its highly successful production turning center incorporates the Index SingleSlide guide system and features three turrets to maximize the number of tools simultaneously in the cut. Index is participating in Westec via Protek CNC, its distribution partner for California and Nevada, and will be located in Booth #610.
Unique in its design and performance, the Index SingleSlide system provides two degrees of movement in one plane. The system is composed of guide strips with a wear- and friction-reduced coating and hardened and surface-treated guide plates. SingleSlide allows for high dynamic response while providing strong damping performance, resulting in lower cycle times, tool life increases of up to 30 percent and excellent part quality.
The C200 Fanuc incorporates three VDI25 turrets that accommodate 14 tools each. The ability to apply all three turrets simultaneously allows for dramatically reduced cycle times. Operators can apply two Y axes to the main spindle or one Y axis on both the main and counter spindles to further optimize the production of complex parts.
The C200 Fanuc uses Index’s cooling concept, whereby heat generated by the spindles, hydraulic unit and control cabinet is captured and removed through a central fluid circuit. This efficiently transfers heat energy from the machine without dissipating it to the surrounding environment. The system can be connected to a local cooling unit or central system, making it highly adaptable to a shop’s existing production.
