Cutting & Grinding Fluids Lubrication Additives Grease Lubricants Tribology Product News Gears
Lubriplate Introduces New Style Aerosol Spray Cans
Introducing Lubriplate's new style aerosol spray cans with secure straw dual spray nozzle. These spray cans offer a dual spray nozzle with a permanently attached straw, a comfort trigger recessed to help prevent accidental discharge and a dual position spray with the straw in the up position for precision pin-point applications. Highlights include:
Chain & Cable Fluid - Penetrating Oil, a superior, cleansing, non-gumming penetrating oil for wire rope, chains, cables and general lubrication. It prevents rust and corrosion.
Gear Shield Extra Heavy, a tough, tacky, extreme pressure lubricant developed for the lubrication of open gears, slides, pins and other applications where an adhesive lubricant is needed.
X-357 Extreme Pressure Lubricant, an extreme pressure lubricant that penetrates and adheres. Water resistant and unaffected by temperature extremes. For use on pintle hooks, slide axles, open gears, fifth wheels and more.
Metalworking Fluid, a specially developed product designed for metalworking operations. Excellent for drilling, tapping, cutting and grinding.
Biodegradable Penetrating Oil, an eco-friendly, bio-based, biodegradable (Pw1), lubricating oil for general lubrication. Provides a long lasting protective film that prevents friction, wear, rust and corrosion.
Spray Lube 'A' - White Lithium Grease, a super multi-purpose, white lithium-based grease of medium density. Sprays like a fluid, congeals to a grease. Excellent for latches, locks, hinges, tools, battery terminals and other hardware.
Marine & Auto Guard, a multi-purpose penetrating oil. This “wet start” product can be used on  wet plug wires and distributor caps. It provides excellent moisture displacement properties and prevents rust and corrosion.
Additionally, Lubriplate offers ten different NSF H1 registered food grade lubricants with the new style aerosol spray cans.
lubriplate.com
