Open Mind Technologies Highlights CAM/CAD Software at IMTS 2026
Open Mind Technologies will highlight the latest hyperMILL 2026 CAD/CAM Software Suite at IMTS Booth #133351.
Open Mind will be showcasing the recently introduced hyperMILL 2026, featuring a broad range of new and enhanced machining strategies and programming capabilities designed to increase programming speed, machining reliability and surface quality. The latest software suite delivers significant advancements for 2.5D, 3D, precision 5-axis and mill/turn machining applications, enabling manufacturers to achieve greater productivity and process control and many partner booths.
Attendees visiting Open Mind at IMTS 2026 will be able to see tutorial demonstrations of hyperMILL 2026 technologies and learn how the latest CAD/CAM innovations can improve productivity, process reliability and machining performance across a wide range of manufacturing applications. Unique parts made using hyperMILL will also be on display in the booth.
New and Enhanced Finishing Technologies
The latest hyperMILL 2026 suite introduces major advancements in Rest Machining technology that optimize toolpaths and create smoother machining transitions by automatically detecting rest material while accounting for clearance and feed specifications. The 5-axis Rest Machining strategy has been completely redesigned with new calculation algorithms for “Z-Level,” “Parallel” and “Normal” machining strategies, ensuring precise and reliable machining of complex geometries.
Further improvements include optimized 5-axis cutter orientation determination and enhanced collision avoidance for smoother simultaneous movements. A new “Minimum Clearance Angle” option gives programmers even greater tool control by ensuring machining is performed with a defined clearance angle between the tool shank and workpiece.
