Sandvik Coromant Introduces CoroTurn Plus for Automated Turning Operations
Sandvik Coromant has released CoroTurn Plus, a sensorized turning adapter that brings real time visibility, higher process security and scalable automation to turning operations. By making cutting forces, vibration, chatter and in cut status visible as they occur, the solution helps teams stabilize performance, enhance part quality and consistency, and reduce waste.
CoroTurn Plus combines sensorized tooling with two levels of digital capability. Used with CoroPlus Viewer, it provides real-time, passive insight to support operator decisions. Used with CoroPlus Connected, the same signals enable active, machine-integrated protective actions within defined limits — helping users clearly distinguish between visualization and automated response.
CoroTurn Plus streams live data from the cut to CoroPlus Viewer on a PC or tablet, enabling faster, data driven decisions and traceable continuous improvement. Live visualization and reference processes support precise intervention when trends move outside defined limits. Operators receive over limit audible alerts, can hover to inspect values, and can review and flag deviations to accelerate root cause analysis. As tool condition signals accumulate, teams can identify when an insert is approaching end of life and replace it at the right moment, extending tool life and avoiding unplanned downtime.
For machine integrated control, CoroTurn Plus connects to CoroPlus Connected, fully integrated with the machine’s NC. Users set limits on chatter, load and vibration in software or via NC code — if an unexpected event occurs, the control automatically initiates protective interrupt actions to safeguard components, tools and equipment. These actions are configurable by the end user.
Feed rate- and cutting speed-override configurators enable in-process optimization, while data tracked to component position strengthens diagnostics and continuous improvement. This autonomy lets the machine handle more routine decisions within configured boundaries, increasing effective operating hours, especially during unmanned evening or night shifts, and reducing downtime across the day.
Industrialized features include automatic connect and disconnect from the bar, ready to machine system checks, start and stop of data recording and system unavailable messaging. By storing and documenting cutting data for each run, teams can compare batch performance, flag material deviations early, and maintain end customer documentation and certificates for full traceability. Together, sensorized tooling, visual analytics and NC level integration turn raw signals into enforced limits and actions, making production steadier, safer and more consistent with fewer interventions.
