Streamlining Drivetrain Design
A new engineering tool accelerates early-stage gearbox modeling and optimization
Figure 1—Working with sketcher, user interface and 3D geometry on separate screens.
KISSsoft System Module allows intuitive concept design on a system level. In addition to the elementary components, complete gearboxes can now be designed in a separate module. The focus lies on fast concept building and fast calculations of complex kinematics. This is of benefit particularly in the initial phase of a project, when an engineer needs to be able to roughly model different variants of possible solutions to compare critical criteria.
The KISSsoft System Module is a versatile tool used in various scenarios, including:
- Designing new products based on key requirements.
- Modifying legacy systems for new conditions.
- Re-engineering reference designs.
- Analyzing existing designs documented through drawings.
- Managing and comparing design variants with the same topology.
- Creating databases of gearbox series with different ratios for different torque ranges.
- Visualizing, explaining, and promoting concepts, proposals, and preliminary designs.
- Elaborating on concepts for costs, mass, and size to enable quotations.
- Connecting, managing, and safeguarding KISSsoft files used for modeling individual components.
Working Modes
With KISSsoft, the user can choose between the three working modes: Component Level Only, System Level and Collaborative Approach.
The Component Level Only mode involves using KISSsoft modules other than the System Module. It’s a detailed, low-cost, and time-saving approach suitable for less complex systems where calculations for individual components are done independently from each other. This mode is ideal for projects requiring maximum speed, efficiency, and simplicity.
The System Level mode integrates components into a holistic system, combining power flow analysis, spatial and collision-free arrangement, and top-level requirements-driven conceptual design. It is highly efficient for experienced designers with a deep understanding of all aspects of gearbox or transmission design. It is the mode of choice for most licensees globally.
