Nagel and Gehring recently shared innovative technologies during AMB 2022 including new standards in efficient honing, maximum flexibility in the superfinishing of flat, concave, and spherical surfaces, and efficient internal and external honing of workpieces.
Dillon Manufacturing’s Claw Jaws have an optimized contour which provides a secure grip on the workpiece, and the jaws weight, center of gravity and cutting forces combine to minimize jaw clamping force loss.
Workholding solutions increase throughput which generates uptime because they greatly reduce setup and changeover times. Operators can change workpieces in a highly repeatable manner which significantly increases the quality of the finished part. The primary function of streamlining production is to develop a workholding solution that optimizes the machining of multiple parts at once while maintaining tight tolerances. Below you will find a cross-section of companies that will be showcasing their approach to workholding systems at IMTS from Sept. 12–17 at McCormick Place in Chicago.
Forming tools are expensive, often made from carbide and tool steel. Carbide grinding is often the first choice today because customer requirements have increased and continue to increase in terms of complexity, dimensional accuracy and reproducibility. Apart from that, production must also be significantly more economical.
The variable machining of turned parts has never been easier. This is made possible with Duro-M, the new geared scroll chuck, innovative lens geometry and optimized power transmission by Röhm.
This year marks the 50th anniversary of a revolutionary invention that changed the way today’s manufacturers hold metalworking cutting tools. What has been an industry standard for decades now, the Rego-Fix ER collet is the most widely used clamping system in the world and still produced at the company’s Tenniken, Switzerland, plant.
Big Daishowa specializes in modular workholding that provides flexibility, efficiency and functionality. UNILOCK zero-point workholding provides value through versatile solutions that are simple to integrate into existing machinery and setups. Here, the company examines four tips for choosing the right workholding device.
It is with great sadness Gleason Corporation announces the passing of James S. Gleason, a Gleason board member and former chairman and CEO of the company who died on June 17th at the age of 88 years old. Jim, a great grandson of the company’s founder William Gleason, contributed to the company in various roles, continuing to serve as a director on the board up until his death.
