VBN Components AB in Sweden manufactures extremely wear-resistant materials and is known for "the world's hardest steel," Vibenite 290, and "the world's first 3D-printed cemented carbide," Vibenite® 480. VBN's new heat treatment machine, a so-called URQ-HIP (Uniform Rapid Quenching-Hot Isostatic Pressing), was recently inaugurated at the company.
Press quenching technology for more hardening consistency, improved operator efficiency, and faster throughput of a wide range of gears and other close-tolerance cylindrical components
Press quenching is a tried-and-true process for the controlled hardening of flat, circular close tolerance parts. The process ensures good dimensional control and uniform hardening, thus allowing for seamless processing post heat treatment.
Quality control, EV components, energy consumption and material influences are just a handful of topics being discussed in heat treating today. New heat treat methods and global trends will be the topic of conversation later this year at Heat Treat 2023. Here’s a round-up of some stories circulating across key market segments.
Solar Atmospheres of California (SCA) successfully installed a brand new 14-foot-long car bottom Air Furnace with a total load capacity of up to 30,000 pounds. The furnace was surveyed in accordance with AMS2750 and is uniform within ±10°F (Class 2). The furnace has a working zone that is 60-inches square by 168 inches long and handles a workload up to 30,000 pounds. With a maximum operating temperature of 1450°F, this furnace accommodates not only the tempering of large tool steel components but also age hardening of 15-5 PH, 17-4 PH, 13-8PH and nickel-based alloys, and the annealing of Titanium Forgings.
Solar Atmospheres of Western Pennsylvania is pleased to announce the approval of a critical Boeing specification for the oil quenching of alloy steels in accordance with Boeing’s specification BAC 5617.
Solar Atmospheres of Western PA successfully vacuum heat treated two massive H13 extrusion dies at their Hermitage PA facility. Their newest high performing Solar Manufacturing 10-Bar 600 Horsepower high pressure gas quench vacuum furnace was able to fully harden two huge H13 extrusion dies in successive cycles.
Solar Atmospheres of Michigan, formerly Vac-Met, has recently purchased 18,000 square feet of plant space on four plus acres in Chesterfield Michigan. The new building is 20 miles Northeast of the two existing Vac-Met facilities which are currently located in Warren and Fraser Michigan.
For the 2014 Orion launch, NASA introduced the Launch Abort System (LAS). This large manifold housing made from 6AL-4V titanium is designed to rapidly propel astronauts away from the main rocket in case of a catastrophic explosion or any other unexpected event. Once fired, the LAS will accelerate the astronauts away from the main rocket at forces up to 10 to 15 times normal gravity (“G’s”). This critical part of the safety system was once again vacuum heat treated by Solar Atmospheres of Western PA for their most recent launch.
Furnaces North America 2022 (FNA 2022), presented by the Metal Treating Institute (MTI), in partnership with its media partner, Heat Treat Today, is the heat-treating industry’s go-to event every other year. FNA 2022 attracted attendees from across North America, including Fortune 500 companies. For three days attendees took part in networking, connections, and learning about the vast changes taking place in emerging technologies, industry trends, and advances in equipment.
