ANCA Will Demonstrate Connected Regrinding Workflow at IMTS 2026
At IMTS 2026, ANCA will demonstrate a connected regrinding workflow bringing together the ANCA MX7 ULTRA, ZOLLER genius measuring technology, and AIMS Connect software to help manufacturers extend tool life, reduce carbide consumption and gain greater control over the regrinding process. Visitors can find ANCA at Booth No. 237406, North Hall, McCormick Place, September 14-19.
Traditional regrinding processes often rely on disconnected systems, manual data transfer and limited process visibility. ANCA’s integrated solution addresses these challenges by connecting grinding, measurement and production data in a single digital workflow.
“The economics of cutting tool manufacturing has changed fundamentally,” said Edmund Boland, CEO, ANCA CNC Machines. “When carbide prices have doubled, manufacturers cannot afford inefficiency anywhere in the process — not in how tools are ground, not in how they are measured, and certainly not in how many regrind cycles they extract from each tool. What we are showing at IMTS is a connected workflow that gives manufacturers the precision and traceability to make every gram of carbide work harder.”
At the center of the workflow is the ANCA MX7 ULTRA, designed for premium surface finish, precision and process stability. Technologies including nanometer-level control, LaserUltra and runout compensation enable high-performance reground tools with consistency. ZOLLER genius provides automated measurement before and after grinding, determining the optimal material removal required and enabling automated data transfer, target-versus-actual comparisons, and comprehensive inspection documentation. AIMS Connect serves as the digital backbone, linking machine, measurement and production data to deliver up to 20% productivity gains, fewer manual interventions and improved traceability across the entire regrinding operation.
ANCA’s recently launched Performance+ program guarantees a minimum 10% cycle time reduction, with documented results reaching 25-35% depending on software, process improvements and wheel selection.
