Automation for Every Shop Size
A new CNC-based application puts cost-effective robot part handling and articulation directly on the machine tool’s control screen, eliminating the need for a separate robot pendant
Through a technology partnership that breaks new ground in the machine tool industry, Siemens presents an automation solution for the busy, multitasking, small to mid-sized machine shop, as it combines a digital twin of the software and programming of its popular Sinumerik 828 CNC, working in tandem with a Kuka robot, to simplify the operation and programming in part handling for the machine tool operator. Bringing the concept to life during a recent tradeshow, Kuka Robotics Corporation demonstrated the same control and its robot working in tandem with a Syil vertical milling machine. The machine featured the Syil R1 machine-tending automation package, developed with one of Kuka’s system partners, Waybo, which seamlessly integrates the pick-and-place, part articulation, and communications with the CNC onboard, all at a very attractive price point.
The goal of the program, according to Frans Buikema, chief marketing officer at Syil, is to offer the small and mid-sized shops an entry point into automation without major capital investment. Likewise, as Ron Bergamin, key technology manager for machine tool automation at Kuka, adds, the ROI can be very short, as this automation advancement allows the addition of a lights-out second or third shift at job shops of almost any size. Automation is the key, and this cooperative engineering venture has opened a new chapter for small to mid-sized machine shops.
Simplifying Robotics Through the CNC
A bit of history. Only a decade ago, integrating a robot with a machine tool required a separate learning curve for the shop, as robotics required specialized programming and teach-in communications, a separate pendant for operation, and other challenges that often required outside consultants to implement. For small and mid-sized machine shops, this barrier, combined with the cost involved, has resulted in today’s market conditions, where fewer than a quarter of smaller job shops in America utilize automation, especially robotics, in their workdays.
History has advanced. As Tiansu Jing, product manager, Sinumerik CNC systems, explains, “The benefits of this development for the busy job shop are many. Setup, programming, operator interface and diagnostics are all improved with the Sinumerik RunMyRobot/Handling application, as it easily incorporates the Kuka robot with the Syil machine tool.” The teach-in functions are implemented through the Sinumerik Operate HMI system on the control, while the proprietary Sinumerik RunMyRobot/Handling capability of the CNC seamlessly integrates with the Kuka robot control. Jing further noted that, since there is no need to learn robotic programming, start-up time is reduced and the robot’s separate control pendant is eliminated, simplifying the operator’s task. The Sinumerik control’s HMI is used to operate both the machine tool and the robot tender, with all commands and operating conditions displayed on a single screen. He also added that the greatest value for the busy job shop comprised the system’s ability to integrate robots on all its machines, while economizing the learning curve for all the operators. This entire cooperative venture between Siemens, Kuka and Syil made this advancement possible, Jing noted.
From Complexity to Clarity
The Sinumerik 828D CNC utilized in this application is designed for the job shop market’s use of turning centers, milling machines and vertical machining centers (VMCs), but it also offers machine builders and end users the flexibility to enhance the productivity of those machines with this new robotic automation, integrated directly into the control. As Jing points out, “The 828 is scaled to the functionality of the standard machines sold to the smaller job shops. With RunMyRobot/Handling included, programmers can use the same G-code for the robot and the machine tool.”
Designed for the Job Shop Including Affordable Lights-Out Manufacturing
As Ron Bergamin of Kuka notes, “Machine builders can now offer robotics from Kuka mxAutomation, a universal PLCopen-certified interface. It allows the user to program and operate all important robot functions directly in a busy shop’s familiar control environment.”
