Decades in the Making: ANSI/AGMA 2101-E25
Publishing technical standards is a lengthy process that takes place over several years. After the process of the working group writing the document, AGMA staff making changes from the General Ballot, and completing all associated ANSI documents, it is finally time for the working group to turn the document over to AGMA staff for publication. These final publication tasks are to:
- Create publication draft and final formatting to AGMA style guide requirements.
- Go through the publication checklist.
- Final review by the working group leader/volunteers to make sure all final changes from the General Ballot are correctly incorporated.
- File the ANSI BSR 9 form to report the voting summary and register the project as complete with ANSI.
- Final AGMA publication actions:
- Send the new publication to online resellers.
- Add a new publication to the online store.
- Announce the publication via AGMA newsletter, press release, Gear Technology and other AGMA media, etc.
- Notify the technical representative at each AGMA member company of the new publication and how to obtain it.
Sometimes the process can be extra complicated. This leads us to the case of ANSI/AGMA 2101-E25.
Work on the new edition began soon after the publication of the 2004 edition. The committee set out with the goal of using ISO 6336 as the base document and incorporating the unique features of ANSI/AGMA 2001. As this process continued, many in the gear community felt the need to maintain ANSI/AGMA 2101 for use as a fundamental standard and in various application standards derived from it. This resulted in a major course correction back to the basis of the 2101-D04 document and improvement to rating methods and specifications. Having reached the final agreement on the draft, two committee ballots and a general ballot were held to confirm that we had reached consensus.
And without further ado, AGMA is pleased to announce the publication of: ANSI/AGMA 2101-E25, Fundamental Rating Factors and Calculation Methods for Involute Spur and Helical Gear Teeth, written by the AGMA Cylindrical Gear Rating Committee.
ANSI/AGMA 2101-E25—AGMA Cylindrical Gear Rating Committee
Chair: Frank C. Uherek, Regal Rexnord Corporation
Kevin Acheson, The Gear Works, a Division of Machinists Inc.
John Amendola, Sr., Artec Machine Systems
Richard Calvert, Chalmers & Kubeck
Robert Errichello, Geartech
Vanyo Kirov, Caterpillar Global Mining
Yefim Kotlyar, Machine Tool Builders / Emeritus
Jose Martinez Escanaverino, Atlantic Bearing Services
Andrew Milburn, Milburn Engineering
Robin Olson, Regal Rexnord Corporation
Mark Perkins, Peerless-Winsmith
Ernie Reiter, Web Gear Services
Janusz Roszczenko, Philadelphia Mixing Solutions – SPX FLOW
Charles Schultz, Beyta Gear Service
Seth Stelpflug, Metso Minerals
Al Swiglo, Swiglo Metallurgical Consulting
Walt Weber, Flender
ANSI/AGMA 2101-E25 provides a choice of methods by which different gear designs can be theoretically rated and compared.
