Manufacturing Cutting Tools
Hypertherm Associates Highlight Plasma and Waterjet Technology at Fabtech Canada
Hypertherm Associates will highlight its advanced plasma and abrasive waterjet cutting technology along with production-enhancing software at Fabtech Canada 2026, June 9-11, in Booth #7050 at the Toronto Congress Center.
For future-ready abrasive waterjet cutting, the Maxiem 1530X JetMachining Center, part of the recently enhanced Maxiem X Series, is the latest evolution in waterjet technology for cutting complex parts out of most materials, including metal, plastic, glass, ceramic, stone and composites. It also generates surface finishes that often eliminate the need for secondary machining.
Through its enhanced features, the Maxiem 1530X brings superior performance, versatility and productivity at an affordable price. It is engineered for shops that require intelligent performance. Every detail was reimagined to deliver a cutting experience that’s smarter and more intuitive.
The Maxiem X Series boasts the latest version of IntelliMAX, the OMAX premium software suite, which now includes IntelliVISOR Mobile app. IntelliVISOR Mobile enables remote live cut monitoring, system status and problem alerts, remote pause, and instant notifications from anywhere, and is available for iOS and Android operating systems.
Other standard features on the new Maxiem include tank rub rails and an improved abrasive hopper. In addition to reducing the risk of rust, the rub rails prevent damage to the catcher tank and the workpiece during loading and unloading.
The new abrasive hopper is engineered to contain abrasive material within the hopper to avoid external spillage. The seven-pound-capacity hopper provides advanced incoming abrasive filtering and is compatible with an optional Abrasive Clog Detection system that automatically pauses the machine when a clog is detected. With the Abrasive Clog Detection system, an operator can immediately restore flow and keep the machine running.
For improved visibility on the cutting table, under bridge lighting is also an optional feature available on Maxiem 1530X, as is the VersaJET, a completely software-controlled 5 Axis cutting head. VersaJET has a cutting range of 0 to 60 degrees for cutting beveled edges, angled sides, countersinks, and complex 3D shapes. The cutting head virtually eliminates taper on finished parts with automatic taper compensation. Through its high level of positioning accuracy, the VersaJET can cut parts that do not require secondary finishing.
For gouging and flush-cut applications, the Hypertherm Powermax SYNC Series will be on display, showcasing a new standard in air plasma cutting performance and ease of use. The series is designed to simplify operations while maximizing productivity and features built-in intelligence, automated system process setup, and advanced RFID-enabled SmartSYNC torches.
At the core of the Powermax SYNC Series is a patented single-piece cartridge consumable that streamlines operation, delivers up to five times longer consumable life, and provides trackable utilization data for improved efficiency. The series offers a reliable, next-generation solution for professional cutting environments through enhanced cutting power, simplified gouging capabilities, and consistent performance across a range of applications.
For metalworkers who require high-quality cuts at a greater capacity and portability, the Powermax33 XP new air plasma system offers a recommended cutting capacity of 13 mm (0.5 in.) and a severance capacity of 20 mm (0.75 in.), delivering cutting power comparable to some competitive 45-amp systems. With a dual-voltage design, the Powermax33 XP can operate on either 120V or 240V power, making it well-suited for shop or field use.
Additionally, booth visitors will experience the latest enhancements to the company’s XPR line, including expanded capabilities for the XPR460, designed to improve connectivity, productivity, and cut quality. A new control board enables Ethernet LAN capability and MTConnect® protocol support, allowing real-time data access, advanced process monitoring, and remote system visibility from virtually anywhere.
For simpler applications, a new Manual Set mode streamlines operation by retaining settings for repeat jobs, even after power cycles. The XPR gouging capability delivers wider, deeper, and cleaner profiles with minimal post-process cleanup, reducing labor and accelerating weld preparation, while extended arc reach improves access to tight or hard-to-reach areas.
The XPR460 continues to deliver industry-leading cut quality across mild steel, stainless steel, and aluminum, with SureCut technology for precise, bolt-ready holes and accurate bevels, and PlateSaver technology to optimize material utilization and reduce cost per part. Now featuring 460A Nitrogen/VWI capability for high-quality cuts on thick stainless steel and aluminum, along with new 460A Y-Top True Bevel technology for thicker mild steel, the XPR460 increases accuracy, consistency, and overall performance in demanding and automated cutting environments.
Engineers will also be on hand at Fabtech Canada to demonstrate ProNest CAD/CAM nesting software. It is designed for advanced mechanized cutting applications, including plasma, laser, waterjet and oxyfuel. ProNest offers standard features that include part design, CAD import, manual nesting, reporting, costing and quoting, and its fully automated interface reduces programming time from hours to minutes.
hyperthermassociates.com
