Romi to Demonstrate Vertical Machining Center at IMTS
Romi Machine Tools Ltd., a manufacturer of CNC Lathes, Production Turning Centers and Machining Centers, will have a D800AP Vertical Machining Center under power and cutting at IMTS. Romi is sharing space with Siemens in Booth E-4933. The machine will be equipped with a Siemens 828D control. The D800AP will show off its machining capabilities by cutting a "footprint" with the Siemens and Romi logos, along with the IMTS 2010 nameplate. It will also be performing Shop Mill demos. The machine will be tooled with high quality high-speed end mills from Data Flute, and will be equipped with a 30-tool double arm automatic tool changer. Romi personnel will be on hand to demonstrate the D800AP and to answer any questions.
