The new KISSsoft release 2024 is coming soon! This April will bring you the new system module KISSdesign, accelerating the calculation of complex drive trains and replacing the previous KISSsys software.
With the release of version 9, the FVA-Workbench once again sets new standards in gearbox design, enabling the seamless integration of the latest research results into industrial practice. As a groundbreaking interface between collective research and application, the FVA-Workbench accelerates development and innovation in drive technology. This new release is more powerful than ever, with innovative features for flexible load spectra and improvements in FEM components and shaft-hub connections.
A good 20 years have passed since the web-based calculation software eAssistant saw the light of day in the digital world. The software is probably the oldest commercial online solution for the design, recalculation and optimization of machine elements such as shafts, bearings, shaft-hub connections, gears, bolted joints, springs, etc. The calculations are based on internationally accepted standards and guidelines as well as technical literature.
In KISSsoft, 97 (yes, ninety-seven!) plastics are available for calculation of cylindrical and crossed axis helical gears. The materials range from unreinforced POMs and PAs to high performance reinforced and internally lubricated materials.
In the KISSsoft shaft calculation, the proof of fatigue strength can be performed by generating an equivalent stress verification according to the FKM Guideline.
In an urgent assignment, a gear has to be designed, with the engineer already knowing the required reduction ratio, torque and speed. On the manufacturing side, the preferred materials, possible qualities and the reference profiles are specified. This initial situation represents an everyday task.
The new KISSsoft release 2023 comes with numerous novelties. Among others, Gear Mesh Frequencies (GMF) can now be calculated for cylindrical and bevel gears. GMF results are visualized in two different diagrams, i.e. GMF versus rotational frequency of the reference gear, and GMF versus amplitude.
GWJ Technology GmbH has extended the output option of tooth forms of involute gears. GWJ has extended the output of tooth forms in 2D DXF format in its calculation modules single cylindrical gears, cylindrical gear pairs, planetary gear trains, three- and four-gear train systems, gear racks and involute splines as part of the new versions of its calculation solutions eAssistant and TBK.
Liebherr-Australia has announced the expansion of their Perth mining facility, which will strengthen the company’s ability to deliver accelerated zero emission solutions to the wider market. Liebherr-Australia’s growing involvement in the development and implementation of zero emission technology with Australian customers illustrates the necessity for this investment in infrastructure and signifies Liebherr’s commitment to these industry-leading projects.
