• TOPICS
    • Design
    • Manufacturing
    • Inspection
    • Heat Treating
    • Lubrication
    • Materials
    • The Gear Industry
    • Gears by Type
  • MAGAZINE
    • Current Issue
    • Departments
    • Archives
    • Subscribe
    • Advertise
  • NEWSLETTER
    • Subscribe
  • VIDEO
    • Gear Technology TV
      • Ask the Expert Live
      • Revolutions
    • Industry Videos
  • BLOGS
  • BUYER'S GUIDE
  • NEWS and EVENTS
    • Product News
    • Industry News
    • Events
  • ADVERTISING
    • Brand Awareness
      • Print: Display Advertising
      • Online: Web Banners & Keyword Banners
      • Online: Native Advertising (Sponsored Content)
      • E-mail: Custom, White Papers & Webinars
      • E-mail: Newsletter Sponsored Content (Native Advertising)
    • Response & Lead Generation
      • Online: Sponsored Content (Native Advertising)
      • E-mail: Newsletters
      • Online: Buyers Guide
    • Print Advertising
      • Print: IMTS Showstoppers
      • Print: Buyers Guide
      • Print: Manufacturing sMart
      • Print: Specifications
    • Online Advertising
      • Online: Specifications
    • E-mail Advertising
      • E-mail: E-Newsletters
      • E-mail: Specifications
    • Special Promotions
  • CONTACT US
  • AGMA
    • Membership
    • Events
    • Education
    • Emerging Technology
    • AGMA Media
    • Standards
Subscribe
  • Sign In
  • Create Account
  • Sign Out
  • My Account
Home » Topics » Design » Scuffing
Scuffing
Scuffing RSS Feed RSS
Calculated Scuffing Risk: Correlating AGMA 925-A03, AGMA 6011-J14 and Original MAAG Gear Predictions
March 1, 2020
This paper relates specifically to gears that are finish ground and considered high speed per ANSI/AGMA 6011; meshing elements with PLVs (pitch line velocities) in excess of 35 m/s or rotational speeds greater than 4,500 rpm.
Read More
Beautiful on the Inside
November 15, 2018
Dwight Smith
No Comments
Higher Quality Internal Gears
Read More
Predicted Scuffing Risk to Spur and Helical Gears in Commercial Vehicle Transmissions
November 1, 2012
AGMA925–A03 scuffing risk predictions for a series of spur and helical gear sets of transmissions used in commercial vehicles ranging from SAE Class 3 through Class 8.
Read More
Size and Material Influence on the Tooth Root, Pitting, Scuffing and Wear Load-Carrying Capacity of Fine-Module Gears
September 1, 2011
In this study, limiting values for the load-carrying-capacity of fine-module gears within the module range 0.3–1.0 mm were determined and evaluated by comprehensive, experimental investigations that employed technical, manufacturing and material influence parameters.
Read More
Influence of Coatings and Surface Improvements on the Lifetime of Gears
July 1, 2004
Surface coatings or finishing processes are the future technologies for improving the load carrying capacity of case hardened gears. With the help of basic tests, the influence of different coatings and finishing processes on efficiency and resistance to wear, scuffing, micropitting, and macropitting is examined.
Read More
Gear Tip Chamfer and Gear Noise; Surface Measurement of Spiral Bevel Gear Teeth
July 1, 1993
Read More
Classification of Types of Gear Tooth Wear - Part II
January 1, 1993
The first part of this article included abrasive wear with two bodies, streaks and scoring, polishing, and hot and cold scuffing. This part will deal with three-body wear, scratches or grooves, and interference wear. Normal, moderate, and excessive wear will be defined, and a descriptive chart will be presented.
Read More
November 1, 1992
The phenomena of deterioration of surfaces are generally very complex and depend on numerous conditions which include the operating conditions, the type of load applied, the relative speeds of surfaces in contact, the temperature, lubrication, surfaces hardness and roughness, and the compatibility and nature of materials.
Read More
A Rational Procedure for Designing Minimum-Weight Gears
November 1, 1991
Robert Errichello
Read More
Influence of Geometrical Parameters on the Gear Scuffing Criterion - Part 2
May 1, 1987
Read More
Previous 1 2 Next
Free Gear Technology Subscriptions
Subscribe
Subscribe
FEATURED VIDEO
  • Liebherr pallet
    Liebherr Palletizing Cell
June 23, 2022
RECOMMENDED
  • Grinding Slow, Grinding Fine
    June 27, 2022
  • Nondestructive evaluation of stresses and stress-related defects in gears
    June 27, 2022
  • Technology Advancements in EV Inspection
    June 27, 2022
  • IMTS 2022 Booth Previews
    July 14, 2022
  • Preview of 3D Printing at IMTS 2022
    July 14, 2022
    July 14, 2022
    July 14, 2022
    June 27, 2022
  • Subscribe
  • Advertise
  • Contribute
  • AGMA
Powered byAGMA
Copyright © 2022 Gear Technology
  • Privacy Policy
  • Contact
