Ondrives New Gearbox Emphasizes Torque and Speed April 11, 2006 A new line of DC motorized worm and wheel reduction gearboxes from Ondrives is fitted with 24V DC motors that operate at 12V DC. Accor...Read More
Alpha Gears Gearmotor Offers Significant Reduction in Inertia April 11, 2006 The TPM from alpha gear drives Inc. is a geared motor containing a rotary actuator based on an AC servo motor and high precision planetar...Read More
United Grinding?s Newest Machine Grinds Shafts and Chucked Workpieces April 11, 2006 [photo] The Studen S242 from United Grinding is designed for the hard turning and grinding of high-precision applications for both shaf...Read More
New Depressed Center Wheels Introduced by Camel Grinding Wheels April 6, 2006 CGW-Camel Grinding Wheels has introduced Fast Cut Series Aluminum Oxide Type 27 Depressed Center Wheels with N-grade bond for right angle...Read More
Balzers Opens Coating Center in Houston March 14, 2006 Balzers, Inc. opened a new coating center in Houston, Texas. As of January 30, 2006, the Houston Center began coating production of ...Read More
HD Systems Merges with Harmonic Drive Technologies February 6, 2006 HD Systems Inc. and Harmonic Drive Technologies, Nabtesco Inc. have merged, effective Jan. 1, 2006. The newly formed joint companny wi...Read More
Mitsubishi Gear Technology Adds Holroyd Machine January 10, 2006 Mitsubishi Gear Technology Center has added the Holroyd GTG2 precision helical grinding machine to its portfolio. Ian Shearing, vice p...Read More
Samputensil Introduces High Capacity Grinding Machine January 6, 2006 The new 250G generating grinding machine from Samputensili, introduced at EMO 2005 was developed to achieve a shorter cycle time. Acco...Read More
A Split Happened on the Way to Reliable, Higher-Volume Gear Grinding September 1, 2005 Dr. Hermann J. Stadtfeld Bevel gear manufacturers live in one of two camps: the face hobbing/lapping camp, and the face milling/grinding camp.Read More
What to Know About Bevel Gear Grinding September 1, 2005 Dr. Hermann J. Stadtfeld Guidelines are insurance against mistakes in the often detailed work of gear manufacturing. Gear engineers, after all, can't know all the steps for all the processes used in their factories.Read More
