Plastic gears are everywhere
At the dawn of the Industrial
It has long been known that the skiving
process for machining internal gears is
multiple times faster than shaping, and
more flexible than broaching, due to skiving's continuous chip removal capability. However, skiving has always presented a challenge to machines and tools. With the relatively low dynamic stiffness in the gear trains of mechanical machines, as well as the fast wear of uncoated cutters, skiving of cylindrical gears never achieved acceptance in shaping or hobbing, until recently.
