The Hobbing Process
8 Gear Technology advertisers will have booths at IMTS 92, the largest trade show in the Western Hemisphere. The show opens in Chicago on Sept. 9 and runs through the 17th. More than 800 companies from around the world will cover some 931,000 sq. ft. of exhibit space to show the latest manufacturing technology - everything from forming and fabrication products to environmental and plant safety equipment.
"Opportunity is the start of great enterprises." said the Greet statesman Demosthenes, and what was true 2300 years ago is no less true now. Plenty of opportunities which can grow into great - and successful - enterprises are waiting for us right now if we only have the foresight to take advantage of them.
