October 5-8, 1986 AGMA Fall technical Conference & Gearing Exhibit
September 17-19, 1986 Ohio State University Gear Noise Seminar
November 11-13, 1986 SME Gear Processing and Manufacturing Clinic
November 19-21, 1986 Seminar: Gear System Design for Minimum Noise
