Inspection of the cutting blades is an important step in the bevel gear manufacture. The proper blade geometry ensures that the desired gear tooth form can be achieved. The accuracy of the process can be compromised when the blade profile consists of several small sections such as protuberance, main profile, top relief and edge radius. Another common obstacle - are outliers which can be caused by dust particles, surface roughness and also floor vibrations during the data acquisition. This paper proposes the methods to
improve the robustness of the inspection process in such cases.
This paper outlines the basic principles of involute
gear generation by using a milling cutter;
the machine and cutting tool requirements; similarities
and differences with other gear generative methods; the cutting strategy; and setup adjustments options. It also discusses the applications that would benefit the most: for coarse-pitch gears the generative gear milling technologies offer improved efficiency, expanded machine pitch capacity, decreased cutter cost, and a possibility for reducing the number of machining operations.
The paper is not the proof of a discovery, but it is the description of a method: the
optimization of the microgeometry for cylindrical gears. The method has been applied and described on some transmissions with helical gears and compound epicyclic, used on different hybrid vehicles. However, the method is also valid for industrial gearboxes.
Gear honing is a highly productive process for the production of small and
medium sized gears and is used mainly in the serial production of the automotive
industry. The low robustness of the process is a particular challenge in gear
honing. The consequences range from an inadequate gear quality to an early breakage of the honing tool. In order to describe the processmachine interaction, the machining forces must be known.
Noise issues from gear and motor excitation whine are commonly faced by
many within the EV and HEV industry. In this paper the authors present an advanced CAE methodology for troubleshooting and optimizing such NVH phenomenon.
Large bevel gears drive the crushing machines used to process ores and minerals in the hard-rock mining and aggregates industries. This paper is intended to help the reader understand the unique aspects of these machines, and why crushing applications fall outside the traditional automotive paradigm for bevel gears.
In many gear transmissions, tooth load on one flank is significantly higher and is applied for longer periods of time than on the opposite one; an asymmetric tooth shape should reflect this functional difference. The advantages of these gears allow us to improve the performance of the primary drive tooth flanks at the expense of the opposite coast flanks, which are unloaded or lightly loaded during a relatively short work period by drive flank contact and bending stress reduction. This article is about the microgeometry optimization of the spur asymmetric gears’ tooth flank profile based on the tooth bending and contact deflections.
In helicopter applications, the two-piece gear is typically joined by welding, bolts, or splines. In the case of the U.S. Army CH-47D Chinook helicopter, a decision was made to eliminate these joints through the use of integral design. Integral shaft
spiral bevel gears must be designed such that the shaft does not interfere with gear tooth cutting and grinding. This paper discusses techniques to iterate in the design stage before
manufacturing begins.
