The implementation of powder metal (PM)components in automotive applications increases continuously, in particular for more highly loaded gear components like synchromesh mechanisms. Porosity and frequently inadequate material properties of PM materials currently rule out PM for automobile gears that are subject to high loads. By increasing the density of the sintered gears, the mechanical properties are improved. New and optimized materials designed to allow the production of high-density PM gears by single sintering may change the situation in the future.
Chicken Run - the summer that used stop-motion clay figures - is about a group of chickens laying a plan to escape from their farm before they're turned into chicken pies. Distributed by Steven Spielberg's Dream Works, Chicken Run is also about a group of specially-made worms and wheels.
When you to to IMTS, you expect to see hoopla. The mass of machines and bodies gathered in one place should create an unmistakable level of energy and enthusiasm. IMTS 2000 seemed uncharacteristically quiet...
In a modern truck, the gear teeth are among the most stressed parts. Failure of a tooth will damage the transmission severely. Throughout the years, gear design experience has been gained and collected into standards such as DIN (Ref. 1) or AGMA (Ref. 2). Traditionally two types of failures are considered in gear design: tooth root bending fatigue, and contact fatigue. The demands for lighter and more silent transmissions have given birth to new failure types. One novel failure type, Tooth Interior Fatigue Fracture (TIFF), has previously been described by MackAldener and Olsson (Refs. 3 & 4) and is further explored in this paper.
