AST Bearings is a leading supplier of precision ball and roller bearings, cost-efficient rotary assemblies, custom bearing solutions, and related value-added services.
Smart Manufacturing Technology (SMT) is a world-leading company that supplies unique design tools & engineering consultancy solutions for the design, analysis and development of gearbox & transmission systems for the automotive, wind turbine, industrial, marine and aerospace industries.
The Tsubaki brand has been globally recognized for its superior power transmission and motion control products. Since 1917, The Tsubakimoto Chain Company, headquartered in Japan, has been moving the needle forward by constantly innovating new products and expanding its global operations.
