Manufacturing Machine Tools CNC 5-Axis Machining Product News
DMG Mori Offers Latest 5-Axis Horizontal Machining
The DMU 65 H monoBLOCK 2. Generation from DMG Mori is a powerful, efficient, and universal 5-axis horizontal machining center creates all the conditions necessary for successful Machining Transformation (MX).
Process integration, flexible automation solutions, and digital tools ensure efficient and resource-saving production for industries such as die/mold, aviation/space, and general mechanical engineering.
The rigid cast iron machine bed with 3-point support and three guides in the x-axis provides the DMU 65 H monoBLOCK 2. Generation with an optimal basis for powerful heavy-duty machining. Together with the thermosymmetrical design and extensive cooling measures, it achieves a continuous accuracy of up to 5 µm even in the standard version. The robust moving column design with low moving masses ensures high dynamics with acceleration of up to 8.5 m/s². The large working area allows for a wide range of machining operations.
The application spectrum includes workpieces on high clamping towers, complex 5-axis geometries, and reliable deep hole drilling. The E-Pallet further supports the variety of machining operations. The smart interface provides power for fully electric clamping devices and sensors as well as hydraulics and pneumatics. This revolutionizes the classic machine table and enables the use of smart clamping devices which enable the use of intelligent software. Due to the horizontal design, machining benefits from optimal chip removal and good heat dissipation, resulting in maximum process reliability.
The double-sided swivel rotary table is designed for components up to ø 840 x 770 mm and 600 kg and allows flexible machining of workpieces – up to 5-in-1 process integration of milling, turning, grinding, measuring, and gear cutting. The wheel magazine has space for up to 453 tools with a maximum length of 650 mm, a diameter of ø 280 mm, and a mass of 22 kg. The spindle range offers variants up to 30,000 rpm as well as options for machining with 288 Nm and HSK-A 100 tool holders.
The high connectivity of the DMU 65 H monoBLOCK 2. Generation and Celos X control platform—available with Siemens or Heidenhain—pave the way for end-to-end digitization of production. The app-based, intuitive operation and exclusive DMG MORI technology cycles also make handling easier.
us.dmgmori.com
