The optimization begins by training an ML surrogate model on a set of initial samples, which is typically set to a power of two to set up a low-discrepancy Sobol’ sequence to achieve good coverage over the high-dimensional input space. After the initial surrogate model has been fit to the data, this surrogate model is used to select a new microgeometry for analysis that is likely to meet the constraints, achieve a better target, or explore unseen regions of the problem space. For the optimization of eight microgeometry parameters, we use 32 initial samples followed by 168 optimization technique steps for a total of 200 LTCA analyses (see Figure 1), taking between 15 and 20 minutes on a desktop with an Intel Core i9-14900K with 128GB of RAM.
The lowest target found was 0.22 µm, which is lower than the manually optimized baseline microgeometry, which had a target value of 0.28 µm. To demonstrate the effectiveness of the optimization technique, we compare this to a 100,000-sample Monte Carlo simulation using uniform bounds over the optimization space, which took roughly three days to complete across two high-performance desktops. In Figure 1, it can be seen that the lowest target value found within the Monte Carlo study was 0.26 µm, with the 0.1 percentile of microgeometries that met constraints taking the value 0.52 µm. The ML optimization technique found 23 microgeometries that met the constraints with a target value less than this target value, demonstrating that the optimization technique is capable of finding many one-in-a-thousand microgeometries in a matter of minutes. By only performing LTCA analyses that are likely to either yield an improved solution or rule out less-explored regions of the problem space, the ML microgeometry optimization technique is highly data efficient and can thus achieve optimization in a significantly reduced timeframe.
So far, we have compared the baseline and ML-optimized microgeometries assuming that each parameter is known exactly; we refer to these as the nominal microgeometries. To simulate manufacturing deviations, we apply independent Gaussian tolerances to each microgeometry parameter, with lead slope, lead crowning and profile barreling having a standard deviation of 0.6 µm and profile slope and tip relief having a standard deviation of 0.9 µm. The robustness is evaluated by a Monte Carlo simulation requiring 1,000 samples per microgeometry, taking approximately one and a half hours using the previously mentioned hardware. It should be noted that these definitions of microgeometry tolerances were chosen to match the original manual optimization study; however, manufacturing deviations arising from any specific gear manufacturing process can be chosen. After optimization of the nominal microgeometry, we check the robustness. If the robustness is not satisfactory, the user can select a different solution from the optimization to check again for robustness. In Figure 4, we compare the robustness of the manually optimized baseline and optimized microgeometry, observing an improved average first harmonic of TE across both gear pair meshes.
By optimizing the nominal microgeometry, we have also indirectly optimized for a low average TE across both meshes when considering manufacturing tolerances. It should be expected that finding robust microgeometries through optimization of the nominal becomes less effective as the manufacturing tolerances are increased. Given that a typical robustness study requires on the order of 103 function evaluations, optimization thereafter is likely to take over 105 function evaluations (assuming an outer optimization loop requiring one hundred iterations). As demonstrated in this paper, efficient optimization of nominal microgeometry allows engineers to find high-performing candidates in a reduced timeframe; these microgeometries can then be checked for robustness as a post-processing step. The authors are conducting further research into microgeometry optimization techniques that directly consider robustness; however, it is emphasized that optimization of the nominal will remain a practical first step before further robust optimization.
The previous optimization study closely followed the original optimization procedure by allowing the microgeometry on the two input gears to differ; this decision maximizes the optimization potential but does so with an increased cost associated with manufacturing two distinct sets of input gears. Using the microgeometry optimization technique, we will now explore the optimal performance that can be achieved using common input gears. We now vary most microgeometry parameters on the common input gears, varying only the tip relief on the idler (see Tables 2 and 3), with optimization targets, constraints, and load case unchanged from the initial optimization. The optimization was run for two different ranges of tip relief parameters; for each optimization run, a single solution that balanced TE and contact patch quality was selected by an engineer.
For each optimization, a total of 150 iterations (16 initial samples and 134 optimization technique steps) were performed, resulting in a combined runtime of approximately 30 minutes. One solution from each run was selected, and the microgeometry parameters were rounded to the nearest micrometer. Perhaps the most noticeable difference between the two common input gear solutions and the previous noncommon input gear microgeometries is the stress distribution; it is noted that the first of the two common input gear optimization results has smaller stress concentrations (see Figure 5) but at the cost of higher TE. The root sum of squares WHSTE across both meshes takes values of 0.32 µm and 0.34 µm for the two microgeometries; these values are higher than the baseline (0.28 µm) and noncommon input gear optimization (0.22 µm), but still low when compared to the Monte Carlo study (0.1 percentile with value 0.52 µm). Furthermore, the difference in TE between noncommon and common gears reduces when comparing the average TE over tolerances instead of the nominal values (see Figure 6); it would be up to the engineer as to whether this is an appropriate increase in TE for the reduced manufacturing costs. As seen in this section, it is possible to use the optimization technique to find optimal microgeometries under different design constraints; using several runs of the microgeometry optimization technique, a Pareto set of optimal microgeometries can be found from which an engineer can select the most appropriate solution.
In previous sections, the ML microgeometry optimization technique has been used to reduce the WHSTE whilst considering durability through contact patch constraints across both meshes at a single torque of 90 Nm. After successfully optimizing considering a single torque, we now expand the optimization to improve NVH under multiple operating conditions. By reducing TE at other torques, we will search for a torque-robust microgeometry and compare it to the previously obtained optimized microgeometries.
where T is a set of torques. Three torque-robust optimizations are considered:
In all cases, the contact patch constraints remain unchanged from the previous optimizations, considering only a single torque of 90 Nm. Furthermore, we explore the same range of microgeometry parameters as seen in the noncommon input gear optimization as outlined in Table 1.
In Figure 7, the RMS of the WHSTE combined over both meshes for a given torque is plotted for a range of torques for each microgeometry. Torque-robust optimizations B and C have significantly improved NVH performance at very low torques (roughly less than 25 Nm) due to their active targeting of the 10 Nm load case. Furthermore, torque-robust optimization C has a clear reduction in TE at higher torques through its consideration of the 300 Nm load case. Interestingly, torque-robust optimization A, which targeted torques of 50 Nm, 90 Nm and 150 Nm, outperformed the noncommon input gear optimized solution at its individual target torque of 90Nm. In optimization, we cannot guarantee that the global minimum has been found, and two separate optimizations can have similar solutions if their objectives do not contradict. Whilst the torque-robust optimization A indeed found a better solution at 90 Nm than the noncommon input gear optimization, it is emphasized that both solutions are actually very similar; this can be seen by comparing them both against random samples from the Monte Carlo covering the optimization, as seen in the inset of Figure 7.
The optimization of gear microgeometry is a challenging process often carried out by experienced engineers who often balance competing optimization objectives against lengthy calculation times arising from high-fidelity loaded tooth contact analyses. In this work, we have seen how ML microgeometry optimization can be used to achieve efficient optimization of microgeometries, balancing noise, vibration and harshness with other metrics such as durability on a computational budget. By recreating a past manual microgeometry optimization study, we have validated that the optimization technique can yield similar performance to a gear specialist but doing so in a drastically reduced timeframe; providing this powerful tool to an engineer allows them to optimize for a variety of different objectives from which an ideal solution can be selected. Robustness of microgeometries identified by the optimization technique was quantified through computationally expensive Monte Carlo studies. Although the microgeometries identified in this study were robust, direct robust optimization that guarantees performance over manufacturing tolerances has been identified as an area for future research. It is emphasized that the efficient nature of the optimization technique allows it to identify high-performing microgeometries quickly, allowing engineers to identify a varied set of microgeometries for downstream robustness verification and allowing this process to be used as an inner optimization loop alongside gear macrogeometry or wider powertrain optimization.
D. Miler and M. Hoić, “Optimisation of cylindrical gear pairs: A review,” Mechanism and Machine Theory, Vol. 156, pp. 104156, 2021, doi: 10.1016/j.mechmachtheory.2020.104156.
D. Ghribi, J. Bruyère, P. Velex, M. Octrue, and M. Haddar, “A contribution to the design of robust profile modifications in spur and helical gears by combining analytical results and numerical simulations,” Journal of Mechanical Design, Vol. 134, pp. 061011, 2012, doi: 10.1115/1.4006740.
M. Gabiccini, A. Bracci, and M. Guiggiani, “Robust optimization of the loaded contact pattern in hypoid gears with uncertain misalignments,” Journal of Mechanical Design, Vol. 132, pp. 041010, 2010, doi: 10.1115/1.4001485.
Akash Pavan S., S. Periyasamy, Vikram Karthik S. S., and A. Gopalakrishnan, “Microgeometry Optimization of Spur Gear for Electric and Hybrid Vehicle Applications,” 2019 IEEE Transportation Electrification Conference (ITEC-India), pp. 1–5, Dec. 17–19, 2019, doi: 10.1109/ITEC-India48457.2019.ITECINDIA2019-155.
C. Brecher, C. Löpenhaus, and J. Brimmers, “Function-oriented tolerancing of tooth flank modifications of beveloid gears,” Procedia CIRP, Vol. 43, pp. 124–129, 2016, doi: 10.1016/j.procir.2016.02.155.
M. Trippe, A. Lemmer, C. Löpenhaus, and C. Brecher, “Optimizing the operational behavior of bevel gears using a tolerance field-based approach,” Gear Technology, pp. 68–73, Aug. 2019.
S. Lahoti, P. Patil, and J. Wagner, “Gear whine noise reduction by transmission error and contact pattern optimization: Simulation and testing correlation,” SAE Technical Paper 2021-01-1103, 2021, doi: 10.4271/2021-01-1103.
G. Bonori, M. Barbieri, and F. Pellicano, “Optimum profile modifications of spur gears by means of genetic algorithms,” Journal of Sound and Vibration, Vol. 313, pp. 603–616, 2008, doi: 10.1016/j.jsv.2007.12.013.
K. Deb and S. Jain, “Multi-Speed Gearbox Design Using Multi-Objective Evolutionary Algorithms,” Journal of Mechanical Design, Vol. 125, pp. 609–619, 2003, doi: 10.1115/1.1596242.
P. Garambois, J. Perret-Liaudet, and E. Rigaud, “NVH robust optimization of gear macro and microgeometries using an efficient tooth contact model,” Mechanism and Machine Theory, Vol. 117, pp. 78–95, 2017, doi: 10.1016/j.mechmachtheory.2017.07.008.
D. J. Fonseca, S. Shishoo, T. C. Lim, and D. S. Chen, “A genetic algorithm approach to minimize transmission error of automotive spur gear sets,” Applied Artificial Intelligence, Vol. 19, pp. 153–179, 2005, doi: 10.1080/08839510590901903.
B. Blanco, J. L. Escalona, R. Lambert, R. Ling, and O. Balling, “On the definition and effect of optimum gear microgeometry modifications for the gearbox of an offshore 10-MW wind turbine,” Wind Energy, Vol. 26, pp. 717–740, 2023, doi: 10.1002/we.2825.
V. V. Simon, “Multi-objective optimization of hypoid gears to improve operating characteristics,” Mechanism and Machine Theory, Vol. 146, pp. 103727, 2020, doi: 10.1016/j.mechmachtheory.2019.103727.
E. Ben Younes, C. Changenet, J. Bruyère, E. Rigaud, and J. Perret-Liaudet, “Multi-objective optimization of gear unit design to improve efficiency and transmission error,” Mechanism and Machine Theory, Vol. 167, pp. 104499, 2022, doi: 10.1016/j.mechmachtheory.2021.104499.
V.-T. Dinh, H.-D. Tran, T.-D. Bui, D.-B. Vu, D. Vu, N.-P. Vu, and T.-T.-H. Truong, “Multi-Objective Optimization of a Two-Stage Helical Gearbox with Second Stage Double Gear-Sets Using TOPSIS Method,” Processes, Vol. 12, pp. 1160, 2024, doi: 10.3390/pr12061160.
C. Choi, H. Ahn, Y.-J. Park, G.-H. Lee, and S.-C. Kim, “Influence of gear tooth addendum and dedendum on the helical gear optimization considering mass, efficiency, and transmission error,” Mechanism and Machine Theory, Vol. 166, pp. 104476, 2021, doi: 10.1016/j.mechmachtheory.2021.104476.
Y. Lei, L. Hou, Y. Fu, J. Hu, and W. Chen, “Research on vibration and noise reduction of electric bus gearbox based on multi-objective optimization,” Applied Acoustics, Vol. 158, pp. 107037, 2020, doi: 10.1016/j.apacoust.2019.107037.
K. Tamboli, S. Patel, P. M. George, and R. Sanghvi, “Optimal Design of a Heavy Duty Helical Gear Pair Using Particle Swarm Optimization Technique,” Procedia Technology, Vol. 14, pp. 513–519, 2014, doi: 10.1016/j.protcy.2014.08.065.
M. Sedak and B. Rosić, “Multi-Objective Optimization of Planetary Gearbox with Adaptive Hybrid Particle Swarm Differential Evolution Algorithm,” Applied Sciences, Vol. 11, pp. 1107, 2021, doi: 10.3390/app11031107.
A. Artoni, M. Gabiccini, M. Guiggiani, and A. Kahraman, “Multi-Objective Ease-Off Optimization of Hypoid Gears for Their Efficiency, Noise, and Durability Performances,” Journal of Mechanical Design, Vol. 133, pp. 121007, 2011, doi: 10.1115/1.4005234.
A. Artoni, M. Guiggiani, A. Kahraman, and J. Harianto, “Robust Optimization of Cylindrical Gear Tooth Surface Modifications Within Ranges of Torque and Misalignments,” Journal of Mechanical Design, Vol. 135, pp. 121005, 2013, doi: 10.1115/1.4025196.
P. Qiu, N. Zhao, and F. Wang, “Optimum microgeometry modifications of herringbone gear by means of fitness predicted genetic algorithm,” Journal of Vibroengineering, Vol. 18, pp. 4964–4979, 2016, doi: 10.21595/jve.2016.17179.
I. Park, “Multi-objective optimization of the tooth surface in helical gears using design of experiment and the response surface method,” Journal of Mechanical Science and Technology, Vol. 24, pp. 823–829, 2010, doi: 10.1007/s12206-010-0117-x.
H. Wang, D. Chen, F. Pan, and D. Yu, “Multi-objective Optimization Design of Helical Gear in Centrifugal Compressor Based on Response Surface Method,” IOP Conference Series: Materials Science and Engineering, Vol. 423, pp. 012040, 2018, doi: 10.1088/1757-899X/423/1/012040.
Z. Tang, M. Wang, Z. Chen, J. Sun, M. Wang, and M. Zhao, “Design of Multi-Stage Gear Modification for New Energy Vehicle Based on Optimized BP Neural Network,” IEEE Access, Vol. 8, pp. 199034–199050, 2020, doi: 10.1109/ACCESS.2020.3035570.
B. Haefner, M. Biehler, R. Wagner, and G. Lanza, “Meta-Model Based on Artificial Neural Networks for Tooth Root Stress Analysis of Micro-Gears,” Procedia CIRP, Vol. 75, pp. 155–160, 2018, doi: 10.1016/j.procir.2018.04.031.
O. D. Mohammed, A. D. S. Bhat, and P. Falk, “Robust multi-objective optimization of gear microgeometry design,” Simulation Modelling Practice and Theory, Vol. 119, pp. 102593, 2022, doi: 10.1016/j.simpat.2022.102593.
J. A. Korta and D. Mundo, “Multi-objective micro-geometry optimization of gear tooth supported by response surface methodology,” Mechanism and Machine Theory, Vol. 109, pp. 278–295, 2017, doi: 10.1016/j.mechmachtheory.2016.11.015.
J. A. Korta and D. Mundo, “A population-based meta-heuristic approach for robust micro-geometry optimization of tooth profile in spur gears considering manufacturing uncertainties,” Meccanica, Vol. 53, pp. 447–464, 2018, doi: 10.1007/s11012-017-0737-7.
U. Urbas, D. Zorko, and N. Vukašinović, “Machine learning based nominal root stress calculation model for gears with a progressive curved path of contact,” Mechanism and Machine Theory, Vol. 165, pp. 104430, 2021, doi: 10.1016/j.mechmachtheory.2021.104430.
P. Langlois, B. Al, and O. Harris, “Hybrid Hertzian and FE-based helical gear-loaded tooth contact analysis and comparison with FE,” Gear Technology, pp. 54–63, Jul. 2016.
