Perceive, Understand & Perform
AICA and Schaeffler demonstrate the role Physical AI can play in the manufacturing environment
The software was developed and adapted to work within Schaeffler’s specific gearbox assembly process. (All images: AICA)
Conversations on the role Physical AI will play on shop floors across manufacturing took place at every stop I made during the Automate Show in Chicago. Robots—in addition to literally doing the heavy lifting—are now being asked to independently learn from experiences and discover solutions without the assistance of human programmers. At the Universal Robots (Teradyne Robotics) booth, I was treated to some amazing force sensing applications that led to a discussion on a recent gearbox assembly use case between AICA (a partner of UR) and Schaeffler that tapped robots to assemble gearboxes.
Schaeffler faced a variety of unique challenges in design and lifecycle for EVs at a time when the skilled labor force was shrinking. These challenges came to a head during the assembly of planetary gearboxes for an automotive axle. This assembly process exposed the limits of legacy automation: meshing toothed components that rotate independently and vary in tolerance. Conventional programming proved too rigid to adapt, driving up engineering costs and creating production bottlenecks.
The end game was to improve the efficiency and accuracy of their gearbox assembly process. This proved tricky because the parts—like planetary gears—moved freely and unpredictably. This made it hard to program the robots to work effectively. To make things even more complicated, the weight, size, and shape of the parts changed, which slowed everything down. Schaeffler also wanted to be able to switch between different robot brands without a lot of hassle.
Schaeffler sought a solution that could eliminate the dependency on manual labor, handle complex insertion trajectories without rigid, expensive coding, adapt quickly to batch and design changes and scale globally across different robot brands and regions.
These needs led to a partnership with AICA, a Swiss robotics software company specializing in AI-driven automation.
