Sandvik Coromant Introduces New Exchangeable–Tip Drill
Sandvik Coromant introduces its second-generation exchangeable-tip drill, CoroDrill DE10. Engineered for high-volume drilling across all materials, CoroDrill DE10 sets new standards in productivity, efficiency and sustainability. With its innovative geometry, this tool delivers true plug-and-play functionality and uncompromised performance.
Building on the success of CoroDrill 870 for H9-H10 hole tolerances, CoroDrill DE10 introduces advanced features that enhance versatility and operational ease. Users will appreciate the familiar pre-tension clamping interface, thoughtfully designed to align with operator experience while delivering enhanced security. The solution prioritizes robustness, enabling quick tip changes, reliable high-speed drilling and extended drill body life with more tips per tool. Its unique -M5 tip geometry delivers unmatched performance across diverse materials and cutting conditions.
CoroDrill DE10 addresses several common drilling challenges, particularly for manufacturers tasked with producing large quantities of holes in a single operation. With high feed capabilities, the tool achieves superior penetration rates, boosting productivity and lowering the cost per hole. Additionally, both tool inventory and cycle times can be significantly reduced, as CoroDrill DE10 eliminates the need for a pilot hole to guide the drill into place.
As a true plug-and-play solution, CoroDrill DE10 integrates seamlessly into existing setups and is easy to use while enhancing operational efficiency and performance. This innovative tool is designed to streamline manufacturing processes, delivering consistent results with minimal downtime.
“CoroDrill DE10 marks a new era in exchangeable-tip drills,” said Mikael Carlsson, global product specialist for indexable rotating tools at Sandvik Coromant. “Testing against competing solutions has demonstrated its superior robustness, faster and easier tip changes, enhanced feed capacity, extended tool life and reduced cost per hole. It’s an ideal solution for high-volume hole making across all industries, for typical components including heat exchanger plates, automotive components, shafts, pumps and valves and I- and H-beam drilling.”
CoroDrill DE10 also enhances sustainability by enabling higher cutting parameters, faster metal removal and lower cutting forces, which reduces CO2 emissions. Its durable design minimizes waste through predictable wear patterns and maximized tool longevity, further supporting responsible manufacturing goals.
