Mitutoyo America Corporation is pleased to announce the release of the Quick Vision Pro Series, the latest generation of Mitutoyo Vision Measurement Systems. Quick Vision Pro Series machines are packed with high-performance technologies that greatly improves 3D non-contact measurement and productivity. This highly advanced non-contact measuring system delivers even more speed, efficiency, and versatility to the Mitutoyo Vision Measurement line.
The MAZATROL SmoothEz CNC from Mazak has a graphical, intuitive programming mode that minimizes the use and understanding of G-codes. Users answer conversationally displayed questions about the workpiece, and the control constructs the program automatically.
AddUp, a joint venture created by Michelin and Fives, is a global metal additive manufacturing OEM and service provider of powder bed fusion (PBF) and directed energy deposition (DED) technologies. They have launched a suite of new process monitoring software to bolster the capabilities of the FormUp 350 PBF machine: AddUp Dashboards, Recoat Monitoring, and Meltpool Monitoring. This new software suite for its metal 3D printing technology optimizes part quality for prototyping and end-use industrial applications.
At IMTS 2022 in Booth #135621, Marposs will be demonstrating OptoCloud EDU (Electric Drive Unit), its latest generation of 3D precision inspection solutions designed for the electrical vehicle industry. Using multiple laser heads in tandem with contact sensors for measurement and vision inspection, OptoCloud EDU reconstructs the 3D model of complex and articulated workpieces in less than a minute to ensure accuracy of the produced component. For example, it can validate 240 electrical contacts of a motor stator in only 30 seconds, which is 100 times faster than a traditional contact system.
Star Cutter Company will be displaying its newest generation automated NXT 5-axis tool grinder in Booth #237013 at IMTS 2022 featuring detailed graphics that enable visitors to take a self-guided tour of the machine, which will be shadow grinding during the show. The display system will feature the 28 kW spindle option and four-station wheel change capability. It will be equipped with a robot loader and flat blade/insert clamping fixture for live demonstration of automated production. Videos to showcase tooling for form cutters, boring bars and medical hip rasps will also be on display.
At IMTS 2022, United Grinding North America will be featuring the STUDER S131r cylindrical ID-radius grinding machine for I.D. grinding operations where maximum precision is paramount.
Verisurf Software, Inc. announces the Verisurf Engine Builder Performance Package, a complete 3D measurement software, hardware, training, and support package for reverse engineering, designing, building, and verifying high-performance engines and components
