With growing markets in aerospace and energy technologies, measuring hob cutters used in gear cutting is becoming an essential requirement for workpieces and machine tools. Zoller, a provider of solutions for tool pre-setters, measuring and inspection
machines and tool management software,
has developed a new partnership with Ingersoll/Germany for shop floor
checking of hob cutters by a combined
hardware and software approach.
Indexable carbide insert cutting tools for gears are nothing new. But big gears have recently become a very big business. The result is that there's been a renewed interest in carbide insert cutting tools.
and process integration.
