• TOPICS
    • Design
    • Manufacturing
    • Inspection
    • Heat Treating
    • Lubrication
    • Materials
    • The Gear Industry
    • Gears by Type
  • MAGAZINE
    • Current Issue
    • Departments
    • Archives
    • Subscribe
    • Advertise
  • NEWSLETTER
    • Subscribe
  • VIDEO
    • Gear Technology TV
      • Ask the Expert Live
      • Revolutions
    • Industry Videos
  • BLOGS
  • BUYER'S GUIDE
  • NEWS and EVENTS
    • Product News
    • Industry News
    • Events
  • ADVERTISING
    • Brand Awareness
      • Print: Display Advertising
      • Online: Web Banners & Keyword Banners
      • Online: Native Advertising (Sponsored Content)
      • E-mail: Custom, White Papers & Webinars
      • E-mail: Newsletter Sponsored Content (Native Advertising)
    • Response & Lead Generation
      • Online: Sponsored Content (Native Advertising)
      • E-mail: Newsletters
      • Online: Buyers Guide
    • Print Advertising
      • Print: MPT Expo Showstoppers
      • Print: Buyers Guide
      • Print: Manufacturing sMart
      • Print: Specifications
      • MPT Expo Show Guide Advertising
    • Online Advertising
      • Online: Specifications
    • E-mail Advertising
      • E-mail: E-Newsletters
      • E-mail: AGMA Industry News
      • E-mail: Specifications
    • Special Promotions
  • CONTACT US
  • AGMA
    • Membership
    • Events
    • Education
    • Emerging Technology
    • AGMA Media
    • Standards
Subscribe
  • Sign In
  • Create Account
  • Sign Out
  • My Account
Home » Topics » Inspection
Inspection
Inspection RSS Feed RSS
A Rational Procedure for Designing Minimum-Weight Gears
November 1, 1991
Robert Errichello
Read More
Viewpoint
November 1, 1991
Dear Editor: In Mr. Yefim Kotlyar's article "Reverse Engineering" in the July/August issue, I found an error in the formula used to calculate the ACL = Actual lead from the ASL = Assumed lead.
Read More
Recent Developments in Gear Metrology
November 1, 1991
Metrology is a vital component of gear manufacturing. Recent changes in this area, due in large part to the advent of computers, are highlighted in this article by comparison with more traditional methods.
Read More
Single Flank Measuring; Estimating Horsepower Capacity
September 1, 1991
Robert Errichello
Question: What is functional measurement and what is the best method for getting truthful answers?
Read More
SPC Acceptance of Hobbing & Shaping Machines
September 1, 1991
Read More
Full-Load Testing of Large Gearboxes Using Closed-Loop Power Circulation
September 1, 1991
This method of testing large gearboxes or, indeed, any power transmission element, had numerous advantages and offers the possibility of large savings in time, energy, and plant, if the overall situation is conducive to its use. This usually requires that several such units need to be tested, and that they can be conveniently connected to each to each other in such a way as to form a closed-loop drive train. No power sink is required, and the drive input system has only to make up power losses. The level of circulating power is controlled by the torque, which is applied statically during rotation, and the drive speed. Principles, advantage, and limitations are described, together with recent experiences in the only known large-scale usage of this technique in Australia.
Read More
Gear Fundamentals Reverse Engineering
July 1, 1991
Yefim Kotlyar
Whether gear engineers have to replace an old gear which is worn out, find out what a gear's geometry is after heat treatment distortion, or just find out parameters of gears made by a competitor, sometimes they are challenged with a need to determine the geometry of unknown gears. Depending on the degree of accuracy required, a variety of techniques are available for determining the accuracy of an unknown gear. If a high degree of precision is important, a gear inspection device has to be used to verify the results. Frequently, several trial-and-error attempts are made before the results reach the degree of precision required.
Read More
The Lubrication of Gears - Part II
May 1, 1991
Robert Errichello
Read More
Our Experts Discuss...
March 1, 1991
Read More
The Lubrication of Gears - Part 1
March 1, 1991
Robert Errichello
Read More
Previous 1 2 … 61 62 63 64 65 66 67 68 69 70 Next
Free Gear Technology Subscriptions
Subscribe
Subscribe
FEATURED VIDEO
  • Helios1
    Forest City Gear Taps Helios Gear for Custom Cutting Tools
January 18, 2023
RECOMMENDED
  • Precision Equals Performance at ZPE GripTec
    October 12, 2022
  • State of the Powder Metal Industry
    October 12, 2022
  • The Afterglow of Furnaces North America 2022
    October 12, 2022
  • Reigniting the Educational Infrastructure
    December 5, 2022
  • Profile: Continuing Education and Training with the AGMA
    December 5, 2022
    December 5, 2022
    December 5, 2022
    October 12, 2022
  • Subscribe
  • Advertise
  • Contribute
  • AGMA
Powered byAGMA
Copyright © 2023 Gear Technology
  • Privacy Policy
  • Contact
