Fully electric vehicle drives usually require two-stage, non-switchable transmissions. One would think that this greatly simplifies the production. Finally, the described transmission structure has just four gears, distributed on the drive shaft, the second stage with fixed wheel and intermediate shaft as well as the axle drive wheel. But the conditions are not that simple: First of all, the engine speeds of the electric drive with up to 16,000 rpm are much higher than those of the combustion engine. For this purpose, electric motors deliver an almost constant torque over a wide speed range. Unlike the combustion engine, it is already attached to the transmission from zero speed. In addition, there is an additional boundary condition that makes production much more demanding than with the conventional powertrain.
With its brand-new 300GMS nano Gear Metrology System, Gleason presents a world- first at Control Show 2022, May 03-06, Stuttgart, Germany. The capability of measuring gears at sub-micron level, executing advanced waviness analysis and evaluating gear noise using the most advanced analytical tools, make the 300GMS nano ideally suited to support automotive e-drive production with minimum noise requirements.
The transition to EVs will lower transport emissions, and adoption can be accelerated by increasing their efficiency. EVs that take advantage of aluminum components can travel further per charge, helping to overcome range anxiety. Automotive manufacturers who select machining tools optimized for aluminum will be able to produce high-quality aluminum EV components ― helping to support the shift to greener travel.
Hexagon’s Manufacturing Intelligence has released a comprehensive report entitled "Recharging the Automotive Market." The body of work was produced by Hexagon and draws from the original research conducted with Wards Intelligence and Informa Tech Automotive Group (ITAG).
New drive technologies in e-mobility are changing the requirements for gears and, therefore, the quality of the tooth-flank surfaces. Manufacturers of gears have to adapt their manufacturing process accordingly. It’s good to be able to rely on a technology partner with expertise covering the entire range of production processes and technologies, which enables them to find suitable solutions even for special challenges.
Virtual prototyping (VP) is an area where huge advances have been made. As gear and transmission systems, and the methods of their production, become more complex and more interdependent, finding ways to use VP across the entire development process—from the initial design, through analysis, right up to manufacturing—ultimately means gaining a better understanding of system performance and efficiency.
