The fascination of the automotive differential has led to the idea to build a second differential unit around a first center unit. Both units have the same axes around which they rotate with different speeds. The potential of double differentials as ultrahigh reduction speed reducers is significant. Only the tooth-count of the gears in the outer differential unit must be changed in order to achieve ratios between 5 and 80 without a noticeable change of the transmission size.
The objective of this paper is to develop a method for the algorithm-based design and optimization of the macrogeometry of stepped planetary gear stages.
The objective of this paper is to improve the methodology for determining the tooth flank temperature. Two methods are proposed for assessing scuffing risk when applying AGMA 925 for high-speed gears. Both methods provide similar results.
A calculation-based study of different variants with regard to contact ratio and tooth root geometry to compare the results from the 2019 version of ISO 6336 to the previous version, released in 2006.
For certain operating conditions and environments, liquid lubrication of gear drives is not possible, or can only be implemented with great restrictions or at high cost.
This report focuses on the combined consideration of the infeed and the subsequent axial machining with additional variation of the workpiece width in order to evaluate the influence of the infeed with increasing or decreasing full cut area.
A validated simulation model is used to analyze more in-depth investigations into the influence of a stochastic course of the pitch error on the quasi-static excitation behavior.
