Due to near-net shape production, additive-manufactured (AM) gears have a high potential to decrease costs and increase resource efficiency. The decreasing product life cycles as well as the increasing individualization of components demand high flexibility in manufacturing processes
Variable loads resulting from a working process, starting process, or operation near a critical speed will cause varying stresses at the gear teeth of a drive system. The magnitude and frequency of these loads depend upon the driven machine, the motor, the dynamic mass elastic properties of the system, and other effects.
Gear skiving offers great opportunities
for production with step-changing
productivity, particularly for internal gears,
whilst offering high-quality finishing
capabilities and being applicable on a
5-axis machine tool with its inherent
flexibility and multifunctionality.
The research presented in this paper extends the work done on CAD-based simulation approaches with an investigation of the surface topography of gears produced through gear skiving and the investigation of the cutting tool characteristics on the geometry of the produced gear. The study is complemented with the investigation of the cutting forces required in the machining process.
To increase cost efficiency in wind turbines, the wind industry
has seen a significant rise in power density and an increase in the overall size of geared components. Current designs for multimegawatt turbines demand levelized cost of energy (LCOE) reduction, and the gearbox is a key part of this process. Since fatigue failures nearly always occur at or near the surface, where the stresses are greatest, the surface condition strongly affects the gear life. Consequently, an improved surface condition effectively avoids major redesign or increased material cost due to an increase in part size. Additional finishing methods such as shot peening (SP) and superfinishing (SF) significantly increase the gear load capacity, but these effects have not yet been adequately considered in the current ISO 6336 standard or in any other gear standards. The combination of SP followed by SF will be described here as an “improved gear surface” (IGS).
The fascination of the automotive differential has led to the idea to build a second differential unit around a first center unit. Both units have the same axes around which they rotate with different speeds. The potential of double differentials as ultrahigh reduction speed reducers is significant. Only the tooth-count of the gears in the outer differential unit must be changed in order to achieve ratios between 5 and 80 without a noticeable change of the transmission size.
