Tooth contact under load is an important verification of the real contact conditions of a gear pair and an
important add-on to the strength calculation according to standards such
as ISO, AGMA or DIN. The contact analysis simulates the meshing of the
two flanks over the complete meshing
cycle and is therefore able to consider
individual modifications on the flank
at each meshing position.
In co-operation with Voith, a major transmission manufacturer in Germany, Heller has developed a process that significantly enhances the productivity of pre-milling and gear milling operations performed on a single 5-axis machining center.
The machine element package by KISSsoft for the design and optimization of components like gears, shafts, bearings and others is now available in the new version 04/2010.
If you've read any business publications lately, chances are you've seen an article or two covering language and cultural barriers in the global marketplace.
