First, the facts: powder metallurgy is a cost-effective method of forming precision net-shape metal components that allows for more efficiently designed products. It saves valuable raw materials through recycling and the elimination of costly secondary-machining. PM competes with wrought steel gears as the technology continues to advance. You'll find PM components in everything from automobile transmissions to aircraft turbine engines, surgical equipment and power tools.
RCD Engineering's switch from manual to CNC hobbing operations breaks gear manufacturing lead time records with
Bourn & Koch 100H in their gear production pit crew.
Gear hobbing is one of the most productive manufacturing processes for cylindrical gears. The quality of the gears is a result of the tool quality, the precision of the workpiece, tool clamping and kinematics of the machine. The dry gear hobbing process allows machining of gears with a quality according to the DIN standard up to IT 5. To evaluate which gear quality is possible to machine with a given clamping and hob, it is useful to simulate the process in advance.
