What's the perfect vacation destination for a gear aficionado? Aspen? Too trendy. Miami? Too humid. For a true machinery enthusiast, the perfect vacation is a gear museum road trip.
The need for improved power transmissions that use gears and gearboxes with smaller overall dimensions and with lower noise generation has left manufacturing engineers searching for different methods of gear processing. This search has led to the requirement of hardened gears.
