Gear designers today are continually challenged to provide more power in less space and improve gear performance. The following article looks at some of the most common ways to increase the power density or improve the performance of gear trains. The author also takes an in-depth look at the case of a steel worm mating with a plastic helical gear and explores ways to optimize this increasingly common configuration.
More and more gear shops are wrestling with the issue of whether or not solid modeling is right for their gear design work. The Q & A Page of The Gear Industry Home Page has had numerous questions asking how to model gears in solid modeling applications such as AutoCAD, Solidworks and Pr/Engineer. Given the problems people have been having, we are presenting the step-by-step process for modeling gears in Pr/Engineer, but first we thought it would be a good idea to explore the question of whether or not you should even try to design gears using Pro/Engineer or any other 3D solid modeling program.
It should be obvious by now that gears are more than just mechanical components. We have brought you movies with gears and Shakespeare with gears, jewelry made out of gears and so on. Now we, the humble staff at Addendum, are proud to present gears in the world of music.
The American Gear Manufacturers Association (AGMA) is accredited by the American National Standards Institute (ANSI) to write all U.S. standards on gearing. However, in response to the growing interest in a global marketplace, AGMA became involved with the International Standards Organization (ISO) several years ago, first as an observer in the late 1970s and then as a participant, starting in the early 1980s. In 1993, AGMA became Secretariat (or administrator) for Technical Committee 60 of ISO, which administers ISO gear standards development.
